Ability to ADD to the dev resources section from a branch
  • January 31, 2025
  • 4 replies
  • 56 views
Edwin_G_Gil
I’ve noticed that the “Dev resources” section is enabled if I’m in a main file but it's disabled while in a branch file. Is this an expected behavior or is my version buggy? It's the same issue either on web or desktop app. Thanks in advance.
  • February 4, 2025
Hi ​@Edwin_G_Gil, thanks for reaching out!
We flagged this over to the Dev mode team, and they confirmed that this is a known limitation and currently the expected behavior.
What dev resources would you like to be able to access in a branch? With more context, the team may be able to make improvements in the future.
Edwin_G_Gil
  • February 6, 2025
Happy Thursday ​@dvaliao,
Thank you for the reply. I actually would like the ability to ADD to the dev resources section from a branch. In the current state, I can only add on the main file but there are instances that adding URLs on the branch level would be beneficial as those changes only live on the branch level. Does that make sense?
  • February 6, 2025
Thanks for clarifying, ​@Edwin_G_Gil
This makes sense. We’ve updated your topic into a feature request, and we’ll pass this onto the Dev mode team for future consideration.
Edwin_G_Gil
  • February 7, 2025
Thank you!
