Independent Connection Points for Table Rows/Columns
  • August 16, 2023
  • 13 replies
  • 868 views
If I’m adding detail to the contents of a table in FigJam, I would like to be able to point to a specific row in my current instance, and not generalized direction toward the entire table. Cheers.
Yes please this is so important to have
Yes! I keep having to make my connectors into straight lines that aren’t actually linked to the table in order to keep the connections clear between specific columns or rows of a table.
Adam_Ballhaussen
I need this as well! Would be so useful, especially for Entity Relationship Diagrams
Please add this feature. It’s very difficult to create ERDs in FigMa. Sorry to say this but Miro, Lucidchart and diagram.io do technical diagrams better. I’m forced to use FigMa by my company.
  • April 25, 2024
Thanks for the feedback, All!
We’ll pass this onto the FigJam team for future consideration.
Federico1
  • April 26, 2024
I need the ability to properly create technical diagrams. This is the one sole feature that could greatly improve the process of designing databases.
My company is open to getting Lucid Chart but ideally I’d want to keep all of my work within the Figma ecosystem.
Federico1
  • April 26, 2024
Just found this UML Diagram template. It’s a good temporary fix.
Federico1
  • April 26, 2024
This Figma Widget covers all that I currently need: https://www.figma.com/community/widget/1115755436385457066
If the link changes, search up Figtable by Arthur Fontaine
+1 here. The UML template is a good start but without the connectors pointing right at attribute fields I can’t move tables around and maintain the diagram.
None of the table widgets have cell connectors either, which I think is a Figma technical limitation(?) also.
Caio Galvão
  • September 29, 2025
I strongly agree with this feature request.
While the suggested 'Figtable' widget is a nice tool for organizing table content, it doesn't solve the core problem discussed here: connector anchoring.
The main limitation for creating technical diagrams like UML or ERDs in Figma isn't the lack of advanced table features. It's the inability to anchor a connector to a specific row or column.
We don't even necessarily need specialized UML and ERDs connectors right now; that can be handled with connector labels. The fundamental need is simply the ability to link a row in one table to a row in another. This feels like an intuitive and essential capability for the connector tool.
Caio Galvão
Adding one more thought: I'm concerned this feature request might be undervalued based on its current vote count. A relatively small change like this could be a major gateway feature, attracting a whole new audience of technical users from platforms like Lucidchart, Miro, or Draw.io.
Sometimes, the most impactful quality-of-life improvements are ones users don't know to ask for until they're available. I sincerely hope the product team sees the strategic potential here and that this doesn't fly under the radar.
Caio Galvão
Adding my strong support for this. I wanted to consolidate some feedback, as I've noticed this same core request is scattered across multiple threads, which might be why it appears to have lower engagement than it actually does.
The core problem is the lack of connector anchor points on individual table rows. This is a fundamental blocker for technical diagramming (like ERDs or schemas).
It seems many other users feel the same way. Here are other threads asking for the exact same feature:
make-rows-and-column-in-figjam-table-a-target-and-destination-for-arrows
What's interesting is that the Figma team has already implemented a similar solution for shapes, as seen in this launched feature:
launched-custom-connection-points-on-shapes-in-figjam
It feels like extending this existing logic to table rows would be the natural next step. This single improvement would unlock Figma/FigJam for so many technical use cases and attract users from other specialized diagramming tools.
I hope the product team can see the widespread need for this and consolidate this feedback.
jtino
  • October 23, 2025
+1 should be native
best workaround I’ve found so far is
  • Create a section to group + name table
  • Create a single row table with headers (e.g. Field, Type, Description)
  • Create a single row table for each new row you want to add. You need separate table for each row so that you can add connectors between tables!-->
  • Hit x to select connector → connect table rows
