Combine string variables in text layers
  • September 29, 2023
  • 15 replies
  • 4290 views
Matteo_Gratton
I was trying to find a way to combine more than one string variable together without the need to create to text layers.
My use case is:
  • I have plenty of small string variables with specific details associated with a main variable mode.
  • I have plenty of variables modes.
  • I need to combine some of the variables together to generate a more complex string.
Current possible solutions (both the solutions are not great for various reasons):
  1. Create 2 text layers and connect them with String Variable A and String Variable B.
    [I need to create an auto-layout frame that contains the 2 layers and resize automatically based on text content and if a variable is empty for any reason]
  2. Create a String Variable C that contains String Variable A and String Variable B.
    [I need to copy and paste the content of both Variables A and B into Variable C. If anything change in time for A or B, I have to change also C]
I’d love to have an option to say: this text layer contains Variable A + Variable B (+ can be also a way to add a space, or a character if needed - like you can do in Prototypes when combine different variables).
What do you think? Am I missing anything and overcomplicating something that already works (I was not able to find it!)? 🙏
muh_jad
  • October 31, 2023
i definitely need the answer also
  • November 3, 2023
Thanks for the feedback!
We’ll pass this onto our Variables team for consideration.
Ran_Jakubowicz
I definitely need this one also. 🙏
I want to be able to add variables inside text
for example:
Hi {user_name}
would be mega helpful to have a solution for it.
Martin_Mateos_Sanchez
Great idea 👍
gemmy
  • March 12, 2024
Yes, I need this too. This would be so timesaving to avoid creating slightly different string variables. And please also consider how we can support localisation plural form in one go. Thank you Figma 🙏
Also need this as want to put a product name that could change over time across the life of the product - so want to put text either side of a text string variable and can’t work out how to get the auto layout frame to get the text to wrap (breaks it into three parts - text - variable - text)
Marek_Rutkowski
I also need to combine multiple fields in one text to wrap things
Marek_Rutkowski
i need to have a multiple variables or text
neelts
  • May 25, 2024
Hi @Matteo_Gratton & @Ran_Jakubowicz, you can achieve this by using my plugin, I made a video with a similar examples on working with strings:
In short, plugin uses code expressions right in the local variables window, so when you refer to other variables they will be updated automatically, so no need to manually update the same thing (you can copy formulas from the video description).
Hope this helps!
Oh, and link to the plugin:
https://www.figma.com/community/plugin/1365339609215368041/dynamic-variables
Steven_Twigg
Would really like this feature. It’d help greatly. The workarounds for this cause really big issues in dev handoff.
Matt_Rooney
  • March 11, 2025
+1 to this one. Two cases specifically:
  1. Inline a variable into the middle of a static string
  2. Expand variable-to-variable referencing to let us build strings like:
    1. $sentence = Welcome to $productname, $username
Our content design folks here at $VeryBigCompany would really like to give us a library of standard terms to align to internal standards, but since we can’t insert variables mid-string or build variables by concatenating other variables, we can’t support that ask.
Pim Tournaye
  • April 4, 2025
+1000 to this. Having something like string literals in text layers would be great, especially when testing various terminology or copy.
Mathias_Ole_Brocks
I concur
Pim Tournaye
I didn’t like how the Dynamic Variables made me do things, so I tried only emulating , so I ended up making my own plugin to achieve this, but a recent Figma update broke it. My version basically tried to hack together string literals in Figma, maybe that’s what you were also looking for.
Should I find some more time to work on this, and delve a bit deeper into the Figma API, I’ll gladly share the plugin here as a bandaid solution while we wait for this to be implemented in Figma natively.
Frank_K
  • Active Member
  • November 17, 2025
How is this 2 yrs old and not implemented? How can we design protoypes that work without this functionality?
