Required to use fileReader inside code.js
  • December 29, 2023
  • 265 views
Figma12
I am new to Figma plugin development. I want to read the HTML file using filereader instead the code.js.
I have installed the filereader using npm. now I am facing below error while using require to import the package. As I came to know the require is not supporting in Figma.
Kindly suggest the possible way to import the filereader package.
Gayani_S
  • December 29, 2023
Hey there, I’ve changed the category to “Share an Idea”. You can vote for your feature request.
  • December 29, 2023
You should be able to use this API in the plugin UI. Have you tried? You don’t need to install any npm packages.
MDN Web Docs
