Improve variable dependency visualization
  • March 24, 2024
  • 4 replies
  • 392 views
Maja_Maria_Dawn_Jaakson
We currently have different libraries in which we store different levels/layers of Figma variables (encoding design tokens). In our current set up, we have a Semantic library, with variables pointing to variables in a Themes (light/dark modes) library, and those point to colours in a Primitives library.
Right now, there isn’t an easy way of seeing the library in which a referenced variable exists. If I have a variable x referencing y, it seems like I need to try editing x to see where y is coming from.
Tokens Studio has this great visualisation that you can open in a browser from the plugin in Figma. It’s built using https://reactflow.dev/. I guess the same could be made for Figma variables, but we don’t even need a fancy solution like that one.
Within Figma, even a sticky header would make things less painful. And a “variable explorer” view would make things so much clearer, even if it only let you see one full path through the aliasing graph at a time.
Samuel_Hoh
This would be a great feature.
@Samuel_Hoh
I created a plugin that should solve this problem. It allows you to view and export all variables in JSON or CSS format.
https://www.figma.com/community/plugin/1434720635503158584/variables-design
Aguiar_Leonardo_extern
Highy recommend this plugin that is in active development: https://www.figma.com/community/plugin/1457362132545070106/variable-visualizer
Eugene Ross
  • September 5, 2025
Did you create all these nodes and connections manually or were you able to import anything from Figma or a plugin?
