Allow me to draw lines that don't snap to objects in Figjam
  • May 7, 2021
  • 1491 views
Moore_Cale
I want to be able to draw lines that don’t snap to corners/center points on a shape.
M_Vlad
  • February 7, 2024
Can’t believe this is still an issue. It also seems to be Windows specific, on Mac you can correctly hold pressed one of the ctrl/alt equivalent buttons and it won’t snap, but no matter what combo I try on Windows it will always snap, which is annoying when trying to point out specific things in an image.
Bret_Truchan
Here’s what worked for me:
  1. Drag one of the line endpoints to where you want it. It might snap to an object, but that’s ok.
  2. While still holding down the mouse button, continue to position your mouse where you want the endpoint to be. Wait about two second. The line endpoint should detach from the snapped location and relocate to your mouse position.
