Surface advanced font/type settings in Dev Mode Properties panel
  • November 30, 2023
  • 506 views
Sam_Henri_Gold
Often in my designs, I’ll use an “advanced” font settings that just don’t show up in Dev Mode. Small caps and monospaced digits are the big two culprits. They would either have to know that something looks different, go into design mode, and look at the typography settings themselves, or I would have to remember to call it out.
Here’s a label I have that uses SF Pro’s monospaced digits; there is nothing that hints at this feature being enabled:
  • December 1, 2023
Hey Sam,
Thank you for flagging this! I’ve shared to the Dev Mode team and confirm that we’re missing some fields in “Properties”, they’ll have a look into it. 🙂
(fyi, if you switch to “Code” and “CSS” the settings you mentioned will show in the generated code)
