Feature Request: Recursion
  • July 26, 2023
  • 439 views
Eszter_Schuffert1
For some interactions, I need a component that can nest an instance of their own component so that a part of the interaction can be repeated multiple times recursively.
This request also relates to this post: How to make recursive nested components?
As an example, prototyping a text field that creates a new textfield below the one you type.
Currently, I am faking it by creating one component that has all the states of the textfield. Then, I have multiple components that essentially have an instance of the empty textfield and the next state of the textfield including a new empty one. The new empty one is though a component of the next instance and so on. This bypasses the recursion restriction but it does not scale (as it is limited by the amount of extra components) and is hard to maintain. If I want to make changes, I need to update many components.
If recursion was allowed, one component would be enough as I could just put an instance of the variant within the same component. This would scale and also would be easier to maintain.
gilgongo
  • July 26, 2023
Good call. In the past, tools were either predominantly for prototyping or graphic design and you chose one or the other depending on your goal. Figma seems to be trying to be both in the same tool, but right now it’s about 80% design and prototyping anything of much sophistication is a wash. Things like variables are redressing the balance, but it’s going to be interesting to see how things progress on the “architectural” side.
This could be a game changer on so many accounts
Terrence_Martineau_Nokia
This would be awesome. I have a similar scenario where I want to add collapsible branches of a tree to branch of tree that is in another tree branch etc.
Instead of having one recursive component for a tree branch, I have to create unique groups for each and every level of the tree 😏 And if I need to make changes to the tree group I need to edit all the group separately to keep them in sync.
