Dev export without rounded corners
  • April 9, 2024
  • 15 replies
  • 934 views
It would be great if dev could export without rounded corners applied and or have some export flexibilities
Gayani_S
  • April 11, 2024
Hey @Jason_Kyle, thank you for your feedback! I’ve just shared this internally with the team for consideration.
Community members can share their interest and vote for this feature request. Stay tuned for future updates!
Thank you,
Gayani
Gayani_S
  • April 12, 2024
Hey @Jason_Kyle, our team would love to hear more information on your feedback.
Can you tell us what you mean when you say without rounded corners? Like if the frame/rectangle has a corner radius?
Thanks in advance!
Nick66
  • June 11, 2024
We also need this. I believe they are referring to if a frame has rounded edges or a stroke. A developer will add this in via css and not want this included directly into the image.
EDynam
  • June 27, 2024
Agreed. It’s very painful to have to go an unset all the rounded corners and borders on images to export them without.
_Artware
  • July 12, 2024
We need this too. Rounded corners and strokes are often added using css. I need the developer to be able to download the original rectangular image.
Currently I need to create a duplicate of every single image without a stroke or rounded corners for the development team. It’s really unnecessary busywork.
shawnoyes
  • July 16, 2024
Yes! We need this too. Devs do not want images that have rounded corners. They want to round the corners with CSS. It’s so tedious to export images with square corners for devs! We often build in component bools or variants to easily accommodate turning the rounded corners on/off. It would be so much better if this was just something that could be managed in the export options–even if it was only in the dev mode options.
DD_Team
  • November 4, 2024
I would like it if you could go even further than this, often if there’s a border, rounded corners, overlay etc, we want to do this in CSS rather than all the images having to be styled before being uploaded to a site.
At the moment in the editor you can export the original asset which is often a huge file or the fully styled file.
What would be great is an in-between, that allows you to export the image cropped to the rectangle at the correct size (with the 2x options ect) but without any additional styles applied
The dev team would be much appreciated if this was possible
Clare
  • November 7, 2024
I need this feature as my clients would like to prep the images used in their prototypes but all the images now have the rounded corners even though it’s done in CSS.
Jan_Willem_Hoogstraten
+1
Bryce_Driesenga
+1.
The best workaround I know is to set the corner radius on a parent frame. Then, create a frame without rounded corners inside it, where you can apply your export settings. Make sure to enable "Ignore overlapping layers" in the advanced export settings.
Owenooooooo
  • August 13, 2025
Old topic apparently, but yes. We really need this!
Ben Cavenagh
  • September 16, 2025
Would love to see this implemented!
Martin_Hill
  • September 26, 2025
Yes please, please, please. over 1 year ago this was first posted. Just saying :)
leslie.crosby
I made a forum account specifically to +1 this. To reiterate what a few others have suggested, we really really need an in-between option for exporting assets as devs. The original asset is usually too large and/or uncropped so we can’t use that as-is, yet the fully styled asset has gradients, rounded corners, drop shadows, etc. We just need the cropped asset in its purest form.
For your product team’s user stories:
  • Dev user pain point: It often takes me the same amount of time to merely deal with asset exports as it does to code an entire page.
  • Designer user pain point: I’m certain my designer coworkers do not appreciate me gunking-up their beautiful, organized files with all the images I end up duplicating off to the side, just so I can turn off rounded corners, hide gradients, and re-name them for export.
(It would also be great to be able to change your preferred default file extension for exports. I would love to be able to specify SVG as the default instead of PNG for some projects.)
But for starters a no-rounded-corners mode would be a complete game changer!
Sam Lucchese
  • December 10, 2025
FOUND THIS THREAD AND CANNOT EMPHASIZE HOW MUCH WE NEED THIS
