Variables menu to support display long variable names
  • August 24, 2023
  • 12 replies
  • 1249 views
Neil7
We are transferring design token names to variables in Figma.
Token names are by necessity quite long (they cannot be shortened without losing meaning).
Examples:
dimension-action-padding-vertical-with-label-l
dimension-action-padding-horizontal-with-label-l
dimension-action-padding-gap-with-label-l
When I click into an input field eg. auto-layout/vertical spacing I cannot differentiate the variable names in the list because the window is not rescalable. See image.
I need to be able to see the full names. Preferably immediately without needing to hover over each item in the list.
Thanks keep up the exciting work on variables guys and girls!
Almas_Robert
Hi
I’m using the desktop app. When I list the variables to assign one to a property in the right panel in design mode, there is a problem to see the variable names. If the variable name is long, and/or the default value is long, it is really hard to guess what is what.
Unfortunately when hovering over the variable name do not show me the full text.
Same issue, when using variables in the prototype interactions. For example using the Set variable action. In the drop-down, you can not see the variable names well.
The best way would be some dynamically wider drop-down, and see the variable names in full size, but at least the on hover display also would help.
Hoby-Van-Hoose
  • November 1, 2023
I fully agree. We always need to be able to see the full names of our variables and modes.
I’m at the point with several variable sets where I’m trying to decide the least terrible way to shorten the names of variables, just so we can tell them apart in selection menus in the Figma interface. Parts of words are bad, while acronyms and single letters are tied for worst. We shouldn’t even be considering this.
  • November 2, 2023
Thanks for the feedback, @Almas_Robert!
We’ll pass this feedback onto the team for consideration.
Guy_Lepage
  • November 23, 2023
+1, being able to expand names both on the variables window and when selecting variables is pretty critical.
kmh
  • January 31, 2024
This comes back to the issue with the entire right panel being fixed-width, but having much more features in it now. The same truncation issue comes up with component variant property names and their values.
Dan_C
  • March 27, 2024
Any update on this - major ui bug and should fixed asap considering this is app is largely for deigning UI.
Screenshot 2024-03-27 at 15.01.37
Screenshot 2024-03-27 at 15.01.28
Katrina2
  • May 7, 2024
We’re working on component tokens in our team and variables can become quite long.
It is really hard to pick the right variable, when you can’t see the part of the name, which is differentiating them.
I don’t know why the left side panel with layers is flexible in size. But every panel or menu on the right side is fixed in size, cutting things off. I’m stumbling upon this issue regularly and find it really annoying.
9136
  • July 2, 2024
Interferes. To begin with, at least add a way to see the full name on hover.
Peter_Muller
  • August 22, 2024
+1, at least full name on hover, but even better resizable table columns or panels
Neil7
  • August 22, 2024
We finally implemented our tokens in Figma.
We used folders for naming which worked much better than long names and is more intuitive and similar to ‘old-school’ Figma styles
eg. Token Name:
CODE
sys.color.action.basic.default
FIGMA VARIABLE
SYSTEM >
color/action/basic/default
Figma still has not fixed the issue but I believe we found a better way for designers to understand.
Katrina2
  • August 29, 2024
With the latest Figma update, the right side panel can now be adjusted in its width. Which is nice 🙂 It would still be great, if the width could be increased even further. Long component token names are still being cropped.
But worse: The window for searching variables (screenshot left side) is by far too small. The part of the token name, which differentiates the tokens from another, is being cropped. It’s a guessing game which component token to pick.
Please Figma, improve the search for long variable names. 🙏
Bobby_Davis
  • August 15, 2025
Can’t believe this one hasn’t been remedied yet. Still waiting and hoping…
(truncated in the panel below: sds/semantic/color/interactive/background/primary/)
That was done just for illustrative purposes. In our actual design system’s variables/styles/tokens library, what we’ve done as a workaround is to truncate the first few levels of all tokens. In this case, for semantic colors we’ve decided to truncate “sds/semantic/color”… leaving only “interactive/background/primary” visible for end-users.
Not ideal, as our devs have to create and maintain transforms to sync Figma and code.
Can we somehow make the flyout panels resizable? Or, have them wider when long variable names are present, maybe up to a max-width, but then wrap the long variable string? I don’t love wrapping, but it’s better than truncation.
And yes, I know there is a tooltip now on hover…
… but we’ve learned though user testing that this is not a good solution for our end-users either. It’s cumbersome and prevents quick scanning. We learned that people aren’t using the search function much at all, and most rely on visual scanning of the list.
