Swapped Overlay Position Solution
  • April 18, 2024
  • 4 replies
  • 580 views
Vishal_Ramawat
I came across the problem of “Setting the position of next overlay after Swap overlay”. I searched the community that people have requested the feature for the same and there was no solution.
I tried successfully.
On Overlay 1, I used following interactions consecutively:
Close Overlay and then Open Overlay 2.
Now I could set the Overlay Position as needed, irrespective of Overlay 1 position.
Do let me know if this works for you guys!
@Dario1
Dario1
  • April 18, 2024
Hello @Vishal_Ramawat! Composing interactions worked for me when the events are linked to the Overlay itself. Does it work for you when the interactions (Close + Open 2nd) are attached to a layer within the Overlay?
For example, I want a button within Overlay 1 to close Overlay 1 and trigger Overlay 1.
In my case, the Overlay 1 closes and 2 never opens:
Dario1
  • April 18, 2024
Or say:
In Overlay 1:
  • The left button closes Overlay 1 and opens Overlay 2, positioned Top Left
  • The right button closes Overlay 1 and opens Overlay 3, positioned Top Right
Dario1
  • April 18, 2024
…Actually it works: would appear that Component interactions are getting in the way. Getting rid of them worked fine.
I still find Figma “scripting” and event handling still kinda fragile or very picky.
Vishal_Ramawat
Yeah, it worked for me as well. Like, if you want to create OnBoarding steps, the position of Tips can differ on screen and clicking Next button on each tip can link to next tip.
I guess, it’s the way for now 🙂
