Text converted to vectors should be grouped by letter
mcram
Currently, when text is converted to vectors by flattening, it is rendered as one single vector object. Double clicking reveals all bezier nodes. For complicated letter forms, this can make it difficult to move/manipulate individual letters.
It would be more useful if flattened text were rendered as a group of individual letter paths with each letter’s layer named that particular character. Bezier points could still be accessed by double clicking the letter form.
Hopefully the image will help clarify:
Joshua_Mao
not sure if people are still following this but I found a workaround -
  1. Flatten Text
  2. Export as SVG
  3. Drag SVG back into Figma
Somehow, this process groups the vectors by letter within figma
mcram
  • 27 replies
  • March 23, 2022
Excellent workaround! Thank you!
Hey Figma friends… seems like an easy fix (what do I know though). Can you tidy this one up?
Josh
  • Former Community Manager
  • 1019 replies
  • March 23, 2022
Oh interesting! Thanks for sharing the feedback and workaround. We’ll pass this along and see what we can do here. 🙂
mcram
  • 27 replies
  • October 17, 2022
The results of the workaround posted by Joshua_Mao is exactly how this should work.
Romanr
  • 9 replies
  • April 26, 2023
  1. Flatten text
  2. select a letter, cut.
  3. create empty frame , right click , paste here, fit frame to selection.
mcram
  • 27 replies
  • April 27, 2023
Yes, but it is not always so easy if the letters are complex or have overlaps or lots of letters. It would be so much more efficient to have the letters broken up separately. The SVG workaround is useful but again would be better if not necessary.
Mika_Kuitunen1
I just ran into this while converting an icon font into a set of vectors, the export as SVG and re-import was a helpful workaround but a more flexible flatten would be even better. In my case I needed the characters as individual frames so perhaps building some options into it would be useful as well.
mcram
  • 27 replies
  • October 6, 2023
Well, friends. Figma has announced today that this will be fixed! Huzzah!! Thanks, Figma.
Romanr
  • 9 replies
  • January 30, 2024
@mcram where did you see that?
4 months later doesn’t look like it was changed. Converted text is the same as before.
By the way there was some plugin that done that.
mcram
  • 27 replies
  • January 30, 2024
Hey @Romanr! It is totally fixed! Just choose “outline stroke” on your text and you get a group of separated, vector letter shapes. If you prefer the old way, with one vector shape of all the text, choose “flatten” instead. Awesome!
RonMan
  • 6 replies
  • June 23, 2024
Doesn’t look like anything was changed about this.
Both Flatten and Outline Stroke produce single path shape that’s your problem to separate. There are plugins though that will separate text layer.
