Allow to review component updates of a specific page only
  • June 5, 2024
  • 4 replies
  • 276 views
Fabrice
When I have library updates available for my file, sometimes I just want to apply them to a specific page – not to the whole document.
The Updates panel lets you select Current page, and as a result you only see which components of the current page have some update available. All good so far.
Now if you want to review changes of a component rather than blindly click Update, you select the component in the list and end up in the second-level, Review updates panel. The trouble is: At this point the Current page filter is forgotten and you can only review all the instances of the document.
How can I review one by one the instances of the current page only?
Motivation: I would like to always review and update stuff on the local components page of my file, because if I update this first, a lot of updates will propagate automatically to the rest of the file, saving me a lot of work.
  • June 6, 2024
Thanks for the insightful suggestions! It would be a great tool if we can implement that. Let’s see how others respond to your request.
William_Page
Agreed. Our entire design community could really use this feature at our company. Please.
Ioana_Ionescu
  • April 3, 2025
I’m also having this problem. I don’t want to go through every instance of a component on the page I’m on when I want to update only the components on a specific page. Because I use versions and I want to also have the old designs available.
It would be acceptable if I could go through the instances and update them in the “Review updates “ panel. But here it’s even worse because the instances aren’t in order… Instance 1 of 34 could be on the 3rd page, that instance 4 could be on the 1st page...I’d have to go through 34 instances to find the last 4 on a specific page…
A feature like “Update on current page only” would be much needed.
Ioana_Ionescu
  • April 3, 2025
The solution I found is to detach the instances on the pages I’d like them to remain unchanged.
