Figma Slides - More component features within Slides directly
  • July 1, 2024
  • 10 replies
  • 3029 views
Anna_Grace_Robinson
It would be great if we could create a few custom components within a Figma Slides document. For example: being able to create a custom footer to use on all of your slides, that would contain maybe a company logo, a confidentiality notice, and page numbers.
I’m able to create this component in a Figma Design library of course, and publish it and then access it in Figma Slides, but that has a few limitations:
  1. The component created in Figma Design is not able to use the font and color styles from the Figma Slides document; since it’s made in Figma Design, it either has no styles applied, or it uses those from another library. Then you’ve got multiple color and font styles mixing in the Figma Slides document, when I’d like to just use one set so it doesn’t get confusing. (Especially if we have non-designers editing the deck – the less styles/libraries available, the better.)
  2. I can’t easily make bulk changes to that component that will affect all the slides in only this slide deck. For example, if I have a slide footer that I want to use on all my slides, and it contains the presentation title in it, I want to be able to type that presentation title in once (in the master component), and have it populate everywhere, right in Figma Slides. I don’t want to switch between a published Figma Design library and my Figma Slides doc just to accomplish this.
  3. Having everything in one place I think would help non-designers who are editing decks. If we can give them one place to adjust the copy or content of a slide footer within Figma Slides, that will save them a lot of time. They shouldn’t have to mess around with a Figma Design library just to get some consistent component functionality in Figma Slides.
I see that in the Grid View while in Designer Mode, you’re able to put frames, text, and other elements right on the canvas outside of your actual slides. This is where I’m picturing the slide-specific components would live. Could I just build a quick footer component on the canvas above my first slide, and then drop instances in each slide, and adjust my presentation title and other info on the master component? It would also be great if those components could be part of a saved/published template somehow, so that I could duplicate a saved Figma Slides template into a new document, and immediately have access to a footer component that’s editable and will change on all my slides, only for that document.
ksn
  • July 5, 2024
Hey @Anna_Grace_Robinson – appreciate the thoughtful feedback on slides.
I can say we’re actively working on improvements and features, and this is is super helpful. Especially this:
It would also be great if those components could be part of a saved/published template somehow, so that I could duplicate a saved Figma Slides template into a new document…
I’ll make sure to flag this with the teams that work on Slides internally. For templates specifically, we know it has room to grow.
As you keep working in Slides, please do drop additional comments as you’re able ❤️
Morgan6
  • July 8, 2024
It would be AMAZING if a slide itself could be a component, so you can use the same slide in multiple decks and you only ever have to update it once to update it everywhere.
Ben84
  • July 9, 2024
Components being able to work from Figma Design to Figma Slides and vice versa is a really nice feature. I need it now.
Krystyna_Maria_Baran
Omg yes please! I’m working on a student’s plan. I create a progress bar- component with variants at Figma Slides, and paste it manually 🥹 to every slide, changing the color depending on white/dark background. However, now I need to change the font, and when I make changes in the Design File component, changes don’t show in the Slides- I can’t publish them in student’s plan. If I go for a paid plan, is there an option to apply changes to all instances in Slides?
Shosh_Radunsky
totally would love to have these, a way to have the same item on all pages,
aswell as having a way to save my template for future slides
Charlie123
  • January 24, 2025
Two gaps I see that are preventing me from using Slides in every day work. Let me know if there are already ways to do this and I missed it:
  • Can’t find a way to update an asset library from with Slides: (e.g. collection of components from Figma design file): Doesn’t seem possible to accept recent updates made to a component library. I can only find how to add existing libraries, but I have to remove and then add again to pull updates.
  • Can’t create components to reuse across slides: I want to use Slides for creating wireframes by creating and reusing a few basic components. Without this, it’s essentially no easier than just drawing by hand with lots of copy/pasta in Google Slides
Yanis_Azze
  • March 6, 2025
Tbh Figma slides is completely useless -mainly- because it has no master component feature, we can’t even edit the existing component within a slide converted from a figma file...
Tom_Hendrickx1
+1
This would be a gamechanger and a real USP against other presentation building software!
Fidel_Carrera
It would be really cool if we could create slides inside of a design file so that we don’t have to create multiple Figma files for the same project. I like to structure my design files into three different sections: discovery, design, and miscellaneous. This structure allows me to organize everything inside of one Figma file. Since I can’t create slides inside the design file, I have to create a Figma Slides file and then link to it from a clickable image on the presentation page of the design file in order to close the loop.
Project Design File - Page Structure
Jason Culverwell
Bumping this.
We want our non-design team members to comfortably update the footer (e.g. client name, project name and date) across all slides and in their slide deck only.
Using a component as a footer is a great idea, but it makes no sense that you must edit the original component in the template to see updates in an individual slide deck.
The work around (i.e. cut and paste a newly made local component across all slides in grid view) isn’t friendly for non-designers - and it means that you must remember to do this again every time you add a new slide.
