Z-index property that is independent from Auto Layout
Slava_Bronevitskiy
Currently there is a huge limitation in prototyping possibilities because any dropdown menus appear underneath the following element in the autolayout flow.
I can’t remove autolayout because it would break designs across all useage of design system components and we can’t properly demo prototypes. Anchored by the lack of a customizable z-index property.
Constantine_Zuev
I made a similar proposal some time ago. Unfortunately not too many people seem to understand the value of Z-index of Z-stack 😒
Slava_Bronevitskiy
@anon21722796 Could any of you please reply on this?
Slava_Bronevitskiy
@figma Reply please?
Josh
  • Former Community Manager
  • 1019 replies
  • September 9, 2021
Hey @Slava_Bronevitskiy thanks for sharing this feedback. It’s definitely something the team is aware of and thinking through.
Lorem-Possum
  • 21 replies
  • September 16, 2021
Absolutely necessary feature:
Set z-index for item in auto layout.
So you can send item to backward or forward only visually.
Lorem-Possum
  • 21 replies
We wana Z-indexing while Flexing and Flexing while Z-indexing!
Pierre_Lord
This is a must. Thanks.
  • October 29, 2021
Roger_Junior
Especially when working with auto-layout, positioning elements become so hard because the z-index is tied to the layer order in a way that is impossible to change the z-index without breaking the whole layout (or opting-out of auto-layout completely).
This is a problem mainly with interactive components that have a “pop-up” or something that should appear on top of every other layer, the best example is tooltips!
My suggestion is to solve this as we would solve with CSS, creating a z-index controller that would be set to Auto as default, and if we want we can type any value to force the z-index:
I’ve heard from many people that they were facing positioning issues with auto-layout. What do you guys think about this?
jared_wolf
plus one. Z index would be essential
Constantine_Zuev
Explicit Z-index property has its pros and cons. For a start, it is going to be a mess. Even more a mess if you are using libraries. It is just too easy to abuse. I know same problem exists in CSS, where you often spend hours trying to figure out why something is not in a place it is supposed to be. I would rather see some entirely different way to solve “pop-up” problem.
For example, ability to position overlay relative to interactive component that invokes it.
Here is my quick mockup:
What do you think?
Roger_Junior
I think this would help but won’t solve the problem.
For tooltips, for example, we wouldn’t be able to change the text for each tooltip without creating multiple frames outside our main frame. In this case, it would be best to have the button and the tooltip itself in the same component/frame and adjust the z-position manually.
h.rude
  • 42 replies
  • December 14, 2021
I agree, this would also help for the workflow on my end.
In general having overlays is a problem when using auto layout. So I am always have to find a good combination of contraints with no autolayout and autolayout.
Especially when on hover the hovered element is bigger and maybe even overlapping with items on the left or right, setting the z-index would help a lot!
Currently I have to move these kind of hover-overlays out of the variants canvas to make it work via interaction “open overlay”. This adds again some confusion when it comes to a handoff (to Devs or other Designers). Because suddenly not all states can be found in the variant area.
James_Mitchell
I wrote a small plugin that can reverse the z-indexes in an auto-layout.
It makes use of a hack using flips and reordering that was mentioned in another thread so a native solution would definitely be preferred, but for the time being this should help when you really need it.
Figma
Matt_at_HAUD
Cool, it does its job, quick and easy. 👍
Hey, @James_Mitchell could you maybe rename this to something more descriptive? Like, ‘Reverse Autolayout Z-index’, for instance?
I can’t quite wrap my head around the fact that plugin names are so much out of the blue sometimes. 🙂 Like, good luck finding some plugins after a few weeks of not using them, then recalling ‘Ah, there was this great plugin I need for that’ and then you stare at that list, completely lost… 😅
James_Mitchell
@Matt_at_HAUD I’ll have a think. I chose Easy Z because typing ‘ez’ as a quick action returns it as first result, whereas ‘Rev…’ matches too many other things.
If I can’t think of a suitable name I can anyway add a label to the command to make it more searchable / clear.
eruveo
  • August 1, 2022
An absolute position has been implemented recently.
Screen Shot 2022-08-01 at 7.08.17 pm
ryanleichty
Just ran into this problem. +1 for a z-index property (though I can’t imagine the potential mess/complexity this’ll introduce)
Arvid
  • Active Member
  • 44 replies
  • November 10, 2022
Aaaaand today again I have an issue that would really profit from a change to this behaviour 😦
Alina_Trussova
Are there any updates on this topic? I also came across this problem.
ckeramidas
+1 to this. would love to have an option of layer ordering and auto layout behavior being agnostic from one another (but maybe still self contained within its own component? a literal z-index as it behaves in css might be really really messy). advanced layout > canvas stacking can be handy in specific cases, but for example, if i have a dropdown subcomponent component that can either open upwards, or downwards, or both downwards and upwards at the same time, i cannot apply auto layout to a parent component without either the label above the dropdown or the text below the dropdown appearing in front of the actual dropdown subcomponent, but using absolute positioning for the subcomponent is also problematic, as the parent component will no longer react to different sizing options of my subcomponent.
Kapranov_Anton
Снимок экрана 2022-12-05 в 00.46.17
Yep, Z index is vital in case of using auto layout drop-downs
Cuppa_Rainbows
Would love this, as well
Josh_Loya
  • 5 replies
  • December 11, 2022
I came here looking for ways to make tooltips work inside of an auto-layout frame.
My use case is a tooltip on an element inside of a table. I’ve created the table from nesting auto-layout frames to simulate rows which contain cells. We can now use auto-layout to give the tooltip absolute positioning so it points at the cell; the problem is that the adjacent cells and rows cover up the tooltip.
Joey_Figaro
Having this exact issue right now and its been a struggle. I’m trying to reduce the number of frames I need to chain together a prototype where I have a table that has a button + popover in each row. The first row’s button popover looks great…every row thereafter is broken:
I’ve tried everything I can think of to have z-ordering work as expected and have applied hacks at every place available–the popover component, the button + popover component, within the table…no dice.
I had expected absolute positioning’s z-ordering to work more like in CSS and was surprised when there didn’t seem to be a way to specify the index for an absolute positioned element/component.
