Reorder nested porperties
  • August 24, 2023
  • 544 views
Daniel_Amann
I would like to be able to reorder properties of a component, incl. nested components. To give an example: A boolean shows/hides an instance of a component and I want the properties of that nested component underneath the boolean.
Example:
Properties (these control the visibility of optional elements in a form component [in this case a Select component])
Required
Help text
Validation message
Nested Instances (These control e.g. the labelling of the optional elements through text properties)
FormControl/Label
SelectButton
FormControl/HelpText
FormControl/Validation message
aelveora
  • December 11, 2023
Another small but great feature is order nested properties by using dragger!
asdsad
andrea-hg
  • Active Member
  • August 15, 2025
I need to reorder nested instances too :(
