Add "select all" in preferred values
  • August 10, 2023
  • 353 views
SJH
Please add a “Select/Deselect All” option to preferred values to remove values.
Currently, it takes over 3 seconds per value to remove. If you’d like to change icon families for example, this is very time-consuming. A simple “select all” option would save a lot of time.
Dennis_N
  • December 14, 2023
@SJH You have this option within the “+” menu where you can both select AND deselect components.
SJH
  • December 14, 2023
No, this does not allow you to select or deselect all.
Dennis_N
  • December 14, 2023
Okay, you are right, only all components within a folder, not across:
screenshot
