Component instance navigator
  • October 6, 2023
  • 220 views
I like to treat my frames the way I build character rigs in 3d, with a single master component as the home screen and nested instances for every group and layer with switches for every state of those objects
I want to be able to visualize my entire selection component variants and edit respecting their hierarchy, where I can see how many of the same instance I am editing based on my selection and to navigate all this exposed on the interface, bring to attention with border color the way select works to allow users to jump to that selection.
This will enable workflow in which the user doesn’t have to navigate their layers as much to select components, solves the layer visualization which can’t deal with that many sub groups
Maybe even use a keyboard shortcut to navigate through nested components to hike keeping your previous selection
ksn
  • October 27, 2023
Hey @Isaac_Picado – I may have misunderstood your comments, so please correct me if that’s the case.
Would using the search to lookup the component/variant name help with this? You should be able to search for the name of the variants, and then select multiple from the list.
If I totally missed the mark, can you clarify a bit more (or even offer up some screenshots to visualize what you’d like to happen)?
