Boolean variables > Support for toggling value
  • August 25, 2023
  • 7 replies
  • 1955 views
Axle
It would be nice if we can toggle a boolean variable easily instead of having to use conditional.
Example solutions:
  1. Set variable [variable_name] to [!variable_name]
  2. Set variable [boolean_variable] to [true, false, toggle]
The ability to have the Boolean event be toggle would be amazing. Right now you can only set the Boolean to true or false with a click. With successive clicks you can’t turn it back off - hence the need for the option of Toggle. Updated to note that yes, you can use conditional functionality to make this happen but having it be a single select option is ideal.
To create toggle functionality, you can add a conditional to check the current state of the object, and then set the boolean to whatever state it currently is/is not. It’s extra work, but it does the job 🙂
Axle
  • October 19, 2023
Yup, but it would be better if we can toggle it easily instead of using conditional.
Henrik_Orre1
  • December 6, 2023
+1, this would make boolean variables so much better
joaopesceofc
This is now possible (not sure if it’s a new feature):
Simply add not or ! before the variable
Here it is in action:
Axle
  • February 7, 2024
Not sure if this existed when I posted this, but thanks! This should do the trick.
Oliver_Kierepka1
Please allow the “not operator” in setting boolean variable values.
