After delay transitions don't work in component variants
  • October 9, 2024
  • 51 views
PDCo
I have a scenario. I have a form in which I want to submit a comment.
The comment object is on the screen and is a component with 3 variants:
1 > hidden (note-hidden)
This is the component on the screen where it is at 0% visibility and 1px tall.
2 > transition state where it looks yellow (note-transition)
Note is full size but is a yellow tone.
3 > the final state (note-default)
The note is in it’s normal state.
When I tap the submit on the form button I use a variable to change the variant from note-hidden to note-transition. The variant “note-transition” has an after-delay action to change it from yellow to the normal color. This is the old school 37Signals yellow fade pattern. The issue is that when I use a variable to change the variant, the “after delay” doesn’t work and it just stays as the “note-transition” state. My take is that this transition should trigger and it’s a bug.
ArtMalikoff
  • June 20, 2025
I have the same problem.
