(Minor bug) No animation around skipped slides
  • November 21, 2024
  • 29 views
Damian_Oczki
Minor issue in Figma Slides:
If you set all the slides to animate (e.g. dissolve), then this layout:
[ 1 ] [ 2 ] [ 3 ] [ 4 ] [ 5 ]
works as expected. Changing slides dissolves the view between all of them.
But, if you hide a slide (using “Skip slide” option):
then the animation works between 1-2 and 4-5, but there’s no animation between 2-4. The skipped slide causes the transition to be instant - no dissolve, no push, nothing.
icelk
  • March 21, 2025
Any chance for a fix? With the current behavior we cannot use the skip slide feature in place, but have to move skipped slides to the end of the deck, which is cumbersome in larger decks.
