Export as webP
  • December 6, 2024
  • 8 replies
  • 108 views
David_Galliford
Was told by a Figma rep that there are only 200+ requests for Figma to export as webP - and they didn’t sound positive that it would be integrated.
So, I want to rally the community to push for this feature. There are already paid plugins out there that do this, so there must be a need. Show your support and let’s push the incredible team at Figma to incorporate it!
Luciano
  • Active Member
  • December 6, 2024
You should post this on the “Share an idea” category, where we can vote on it.
David_Galliford
  • December 6, 2024
Great call! Thanks @Luciano
Just changed it 🙂
David_Galliford
  • July 28, 2025
Figma,
Let’s get this feature out there :)
It crunches images while keeping quality.
Dave
Pieta
  • September 1, 2025
I need this desperately, currently have to convert all images through external converters and it takes a lot of time.
If I could bulk export all my layout images in WebP format, that would save me hours from every project.
The file size and loading speed are so important in e-commerce platforms, that all images have to be uploaded in WebP format. It is the difference between 300KB (PNG) and 15KB (WebP) and makes a huge difference in speed tests like Lighthouse
David_Galliford
  • September 2, 2025
There must be a reason why this hasn’t been integrated that goes beyond user-demand. Alas, speculation will get us nowhere.
Previously, I was publishing my images, then using an Action in Photoshop to convert. Still a bit time consuming, so I built a webP converter that watches a local folder. I publish my Figma PNGs to this folder and grab them from my local published folder.
Pieta
  • September 3, 2025
Yeah, I also did some research and I’m now converting images to WebP through terminal after exporting: https://web.dev/articles/codelab-serve-images-webp
But that only helps me. Customers who create content to a website don’t understand any of that and it would be essential for them to use WebP as it really speeds up their sites. Having an export option in Figma would help them out as they are familiar with saving images or exporting them in JPG or PNG format..
JakeMathew
  • November 9, 2025
If you export your design as a PNG or JPG, you can quickly convert it to a highly optimized WebP file using a free utility tool like Picspectra
You can convert any standard format to WebP in seconds here: Picspectra's free online WebP Converter
Pieta
  • November 10, 2025
Sure, there are a million different converters online but what we’re talking about here is streamlining the process of exporting images in the correct format straight away. When you create all images in webp format for clients, the steps add up and it takes a lot of time instead of exporting in the correct format.
