A small suggestion: When using custom weight on a variable font, the dropdown should show the weight directly ("550") instead of "Weight: ..."
  • November 28, 2024
  • 35 views
Aarav_Sareen
  • Figmate
  • November 29, 2024
Hello @Aarav_Sareen, Thank you for sharing your suggestion!
While it may not be a perfect solution, as a workaround, you can try expanding the right panel until you see the number of the weight in the design panel.
Please don’t forget to vote for your idea.
Thank you once again for your input!
