Auto reverse auto-layout order of display
  • March 28, 2024
  • 4 replies
  • 1603 views
malik_d
Auto layout is cool. Thanks Figma!
However, to change the display order, one has to manually change the order of each item in the Layer section, which can be annoying when dealing with too many items in the layout.
A solution would be to add three layout buttons, right below the current ones, that do just that: reverse the order of display.
Much love. I hope this helps!
Names of the button and much more on it on my personal blog on Medium: New Figma Auto-Layout Feature. The Problem | by Malik D | Mar, 2024 | Medium
Jean17
  • December 19, 2024
Having the possibility to switch between auto-layout styles via Variables would be amazing as well
Rory_Byrne
  • May 20, 2025
Agree. Being able to set this like flexbox would be useful
Mueller_Bernhard_SCW_FIXY3
This would help… actually now!
Markus_Schmon
  • November 27, 2025
You can achieve something like that by mirroring the entire element and then replacing the items with their non-mirrored counterparts.
Unfortunately, this doesn't work with components that have both mirrored and non-mirrored variants. When switching variants, the items are mirrored.
So yes, a "reverse item order" function would be great for both axes (left→right to right→left and top→bottom to bottom→top).
