Export local variables as a single file for handoff
  • December 30, 2024
  • 94 views
Taimosa_Eregie
Description:
The feature allows users to export local variables from Figma as a single file, making it easier to share design tokens and maintain consistency across projects.
Current Format:
Currently, local variables in Figma need to be copied individually or manually noted down, which can lead to errors and inconsistencies when transferring information between team members or projects.
Proposed Enhancement:
Implement an export option that allows users to select multiple local variables and save them as a single JSON or PDF file. This file can then be easily shared or imported into other projects or reviewed by developers.
Benefits:
  • Streamlines collaboration by ensuring all team members have access to the same variables.
  • Reduces manual errors and saves time in the design handoff process.
  • Enhances consistency across designs by providing a single source of truth for variables.
Others:
This feature could also include an option to import previously exported variable files, creating a seamless workflow for teams working on multiple projects.
