Words always starting with a capital letter
  • October 20, 2023
  • 4179 views
Hey guys!
I have a problem that all my words start with capital letters right in the middle of the sentence.
I must have some configuration adjusted for this, but I don’t know how it happened. Can I help a resolver?
Thank you very much!
Best answer by djv
Hey Tawany, thanks for reaching out!
It sounds like you’ve selected Capitalize for letter case. More info here:
Figma Learn - Help Center
  • October 20, 2023
words library
  • January 21, 2025
Hi 😊!
It sounds like the text is being automatically capitalized due to a setting or style applied to the text box. Here's how you can fix it:
  1. Check Text Style:
    • Select the text box with the issue.
    • Go to the Text section in the properties panel.
    • Make sure that the Text Case option is set to "Normal" or "Lowercase" (if the default was set to uppercase, it could be causing this issue).
  2. Inspect Auto Layout:
    • If you're using Auto Layout, sometimes text properties can behave unexpectedly when resizing or adjusting. Check if any constraints are forcing capitalization.
  3. Clear Overrides:
    • If a text style has been overridden in that specific instance, you might need to reset it. In the properties panel, check for any overrides and click on the "Reset" button to restore the original style.
