Variables + Smart Animate?
J.D_Posey
Not seeing a way to have variable bool states allow for smart animations in the same way changing variant states allows for it (i.e. if you made a switch that flipped using 2 variants, it’s easy to have them smart animate to each other… but not possible with variables, as variable state changes don’t seem to have controls for animation)
Michael_Kwasiuk
Indeed… this makes the new variable boolean states unusable in prototyping. Since prototypes are ment to represent the production product closely as possible.
  • July 12, 2023
I have been looking for the same thing since the variable update and very surprised that it wasn’t done from the start as it seemed to me the natural way of using them. I also can’t find any info on if it is coming up at any point.
Marshall1
  • July 13, 2023
+1
I need the variable changes to be able to use the same smart animate that the other pieces can use
Bez1
  • 9 replies
  • July 25, 2023
It’s convoluted… But I found a work-around. Variables are set up to trigger any “change to” animations that are set up at the component level.
ie. if you create a toggle component with two variants that smart animate to one other on click, then changing the variant state of that component with variables would also trigger that animation.
The trouble is that sometimes you want variables to be the only thing to trigger that state change, and not any other prototyping interaction options like “on hover” or “on click”. If that’s the case, you can kind of hack it by using the “key/gamepad” interaction, but not assigning any key. You can then set up your animation settings, and when the variable triggers the state change from one variant to another, it will pull those “key/gamepad” animation settings without anything else being able to trigger it.
Melissa_A_Casole
@J.D_Posey im not sure if you’ve already found the solution to this. But during the Figma Expo they do show how to retain the smart animate function while using variables. The trick is to create a variable that holds all the component states.
  1. create a component with multiple states
  2. smart animate between the states
  3. create a text variables that ‘holds’ each state (i usually just name the variable the name of the component state)
  4. create another text variable that will toggle b/t all the other states (name it like ‘currentState’)
  5. Here’s the. magic: for each state variable - for the value, type in the name of that component state. Figma will automatically pick up that state.
  6. Assign the currentState variable to the element on the frame that will toggle b/t states.
  7. All done!
Cat_de_Leon
I’m unable to recreate this using your method. Does this still work for you?
JustJest
  • 20 replies
  • September 20, 2023
How about with a component with one variant and you’re just toggling the layer visibility on and off (ie for a dropdown menu)?
Melissa_A_Casole
Here’s a loom i created showing how to do it
Loom
Cat_de_Leon
That was really super helpful, thank you so much! Can you please take a quick screenshot or show what the prototyping settings looks like for your component/variants?
Melissa_A_Casole
Im so happy it helped! With the variant interactions - b/c it doesnt allow you to add 2 clicks to transition back and forth, one of them needs to be a drag. This is just a way to ‘trick’ Figma.
Melissa_A_Casole
hey there - im not sure you would need a variable for this. You could just smart animate b/t the open/close states. Are you trying to have it where only one dropdown can be open at the same time?
JustJest
  • 20 replies
  • October 17, 2023
Yeah, there are variables that trigger one dropdown menu in a main navigation component being opened at a time. For example, in the navigation component there are different drop downs for a favorites icon button, an account icon button, and a dynamic search field.
I would like to handle this with variables in the few navigation variants (which handle different types of logged in users) instead of having every single combination of opened and closed menus as variants of a component. It would balloon exponentially.
This is something that is easily done in Axure. I was hoping to be able to replicate something like that in Figma.
Hello Melissa, this is really useful, but I have a question, if you need to use this element like a component to reuse in multiple screens is not possible, because appear the legend “Removed Variant bindings from nested instances”. And automatically you cannot use for example the text variant “GaugeTemp”, do you have any clue if this is possible? I created a side navigation with expand and collapse components and variables and works perfectly until I try to convert it into a component.
This was really helpful Melissa, thank you! Looks like there has been an update since this post and we no longer have to define those extra variables, changing the text in the current_state variable triggers the “on click” transition.
Thanks very much @Melissa_A_Casole , this was super helpful.
  • November 14, 2023
Unfortunately, this doesn’t work for me. Have overlooked your video multiple times and can’t get the same functionality to work. 😦 Super bummed out how they don’t have this working yet.
  • November 15, 2023
OOOOOOKIE dokes.
After 5 hours of going through insane hurdles and pulling out my hair - I HAVE FOUND OUT THE PROBLEM.
you HAVE to have the Smart Animate enabled on the COMPONENT LEVEL.
Don’t assign any of the Smart Animations to elements within the component - ONLY component level Smart Animations will apply when changing component level state.
Please, Figma team, save others from this insane stress I just went through and just enable variable changes to be a trigger for interactions!!
  • November 15, 2023
All in all - the real benefit here would have component Variants + Properties just assigned to variables. Would make the entire process far easier
The loom is super helpful, but it would be 10000x easier if Figma just let us add smart animate to a conditional on click interactions. Please, Figma!
pcote
  • 9 replies
  • March 6, 2024
Thanks for explaining! It just make me realize Advanced Prototyping’s UX isn’t very good. Pretty ironic, coming from a company that places design at the core of its values.
Josh_Bernard
Where/how are you applying smart animate?
Ziv_Feldman1
Work for me
Adams_George1
benji.hobson is suggesting below workaround and it worked for me:
Adding any interaction and animation for the component variants.
e.g. In my case, I used Key/Gamepad (leaving the “key” field blank) with Smart animate.
Adams_George1
Workaround:
Add any interaction and animation for the component variants.
