The boolean toggles are now receiving focus with the return key
I often make a selection, and use the return key to drill down into a component to select elements – this no longer works.
See video where I enable the icon, and with the component instance still selected, I hit return and the toggle is focused.
To clarify, I shouldn’t have hit return multiple times in the video. It’s the first time that is the primary issue, as with the component selected hitting return should/used to go a level deeper.
