Yulia_Sokolova
April 22, 2022
Right Side Bar disappeared
  • April 22, 2022
  • 17 replies
  • 23599 views
My Right Side Panel Menu disappeared! HELP! Control+\ does not bring it back!.
JanKragh
April 26, 2022
If the UI is hidden, use mouseclick to go to contextmenu, select “Show/Hide UI”
ezichi_gift
August 17, 2022
This is not working either
Emilie_Oswald_Macaulay
August 22, 2022
I’m having the same issue. Have you found a resolution?
Flavio_Lee_Budoia
November 3, 2022
This is a browser issue. So, if you’re using Chrome, switching to another browser solves it. Probably using the app instead also would do the trick.
No clue about why it happens, though. =/
Just happened with me and going with Safari was the only solution.
Probably updating Chrome should fix it.
Moeslein_Michael
November 15, 2022
I’m having the same issue in the browser. I can hide/show the bottom tool bar, but nothing will bring back my left and right panels.
pkp
November 15, 2022
SInce this is a really old issue I would recommend you the same as mentioned in previous comment try updating your browser. Or try in incognito may be some cache issue. Better download figma application.
February 25, 2023
This just saved my life lol. Thanks for that. Another shortcut that I MUST memorize lol.
May 5, 2023
Mine worked when I logged out and logged back in.
Swikar_Ramdam
July 11, 2023
Go to view>panels>show leftbar
September 5, 2023
This happens when you accidentally zoom the browser window. In chrome, go to View > Zoom Out, or View > Actual size.
From there you can toggle the panels on / off as normal using Command + \
