LAUNCHED: Elements now stick to the top when vertically scrolling in prototyping
  • January 25, 2021
  • 136 replies
  • 100787 views
Justin_Kalaskey
Currently the only function of fixed positioning on an element is to make it persistent in the same spot at all times. While this is useful the majority of the time, there are instances where it would be helpful to have an element become fixed when it scrolls into view or reaches the top of the screen.
For example, there could be a web page that has a secondary navigation below the hero that will become fixed when it reaches the top of the screen and be persistent for the rest of the scroll depth. Then when a user scrolls back up, the element releases from the fixed position when it reaches its original position. You can see this in effect on this page: Develop custom experiences with the Zendesk Platform | Zendesk Sunshine. It could also be used in more advanced manners such as multi-level parallax scrolling.
Zendesk scroll example
This would be very helpful for both engineering and stakeholders to understand functionality, especially when the designer isn’t there to describe it to them. It would also prove useful for user testing to understand if a chosen function works for users prior to spending time in engineering.
Does anyone have any other solution to this that I’m missing?
Thank you in advance and looking forward to hearing back!
mattaningram
  • January 26, 2021
On the web this is called position: sticky and is a very useful feature that is near impossible to document for developers now in Figma. It would be great to have this feature, particularly with offsets like the web version has so it doesn’t only stick to top or bottom exactly.
Brian_Clay
  • January 27, 2021
Would love this!
Bruno_Figueiredo
Right now, you can do this by adding a “subframe” with vertical scroll active in it.
It’s not a great experience but you can build something like that.
FOX
  • January 29, 2021
Hi guys,There is another way to do it. I had the same issue, with a double menu. I have my main header and another header that need to stick and replace my main header. The idea here is to put invisible buttons on your page. 2 exactly: one on hover when you are at the moment when you want your other header to appear in overlay in the top/center, and another one to close this overlay when you go back to the top. it doesn’t work perfectly, but it make the trick. Sorry for my english, I’m a little bit rusty.
Here is the example that I’m working on. I hope it will help you.
Hunter_Wilhelm
Here is another example resource:
w3schools.com
@FOX That does work for headers that change, but it doesn’t show it at all in the scrollable content. It is a good approach for some cases.
We need this feature please Figma!
Mathieu_Lajoinie
There are tricks to achieve it (mouse enter zone at a certain point of scroll for instance) but it’s still kind of hacky and hard to give to a user to test. Would love this feature !
Oleg_Larkin_Designer
We need it feature 100% Figma! We need all modern css visual editor features))
Bradford_Kuntscher
Yes, yes! Need this feature yesterday for sub menus… Need to prototype a fixed position submenu that appears on ‘scroll down/swipe up’ and that disappears on ‘scroll up/swipe down.’ Make sense?
bombadillo
Agreed!
bombadillo
Yes, I need this RIGHT NOW. Exactly this.
Corey_Pruitt
We can’t even prototype the forum page we are reading this request on without this feature. 😉
Renata-Adrienn
Thanks so much, this hack works perfectly for my use-case too! 👏
Marina.Litvin
So need this feature!!!
Emilio_Iantorno
Can you please share how you did this? I think it works great to get the point accross. I see you share the prototype but can you tell me the steps, appreciate it!!
Hunter_Wilhelm
@Emilio_Iantorno At the moment it is not possible to prototype fixed position / sticky elements. That is why we are suggesting that it be added as a feature. Please vote for the feature at the top to help Figma know that we want this feature added.
If you weren’t talking about the main post, please tag or mention the user name to let us know who you are talking to.
  • May 28, 2021
You can duplicate the file to see how it works.
Gisele_Bermudez
Loved this one!!! for all people asking how to do this, just copy this file to your drafts and go to open in editor. There you may see how the Prototype was animated.
Emma_Zhou
  • June 15, 2021
Thanks for the idea! It doesn’t seem to work on Figma Mirror but it works perfectly in web!
Julien_Chatelain
Would love to have this feature added to an upcoming release. Please Figma !
UX_Team_Afya
I didn’t quite work for me 😦
Chad_Lavimoniere
Please give us this! As a combo designer/developer, the inability to model many parts of CSS in figma is a ceiling I bump my head against a lot. When I’m designing for the web I’m thinking about what’s possible on the web, but I can only create figma files with what’s possible to do with figma. If the set of things that figma can do is a subset of the things that are possible to do with CSS, then designers using figma are handicapped by their tools.
JB1
  • July 5, 2021
Please oh please oh please
Wong_Chung_Kam
Yes please I need this scroll to stick…
Corinne_Prainito
You are a legend! Thank you this works perfectly for me too
Jamo
  • July 16, 2021
+1 here. This feature would be essential because this technique is getting more and more common on modern pages, even including this forum 😉
The CSS property for this feature is position: sticky;.
I think the settngs for this feature could be implemented in the “Constraints” section of the element settings.
www.figma.com_file_AcwChGvAaRdi9npeGooPwg_Landingpage_node-id=1:2 (1)
Usually you also define a top margin when using this in CSS. But that’s not as essential as the sticky position itself in my opinion. We would be really grateful if we would at least have the option to make objects position: sticky; top: 0;
Cheers.
@figma @anon21722796
