Hello Everyone, I am not sure if this is the right place to post the query. But I am facing alot of performance issues while using figma with my new Intel 11th Gen i5 11400 on intel uhd 730. I don’t have a graphic card installed in this pc. I have tried multiple drivers and ports but the problem still remain the same.
The figma screen is lagging like hell as soon as I start panning around and turns to completely grey.
@tank666 here’s the attachment for the error. After this the whole screen got grey as soon as I started panning and zoomed in. And I have to restart the figma and it goes again and again not letting me to work at all.
Unfortunately, I have not found another way. You can try changing the parameters in the GPU driver settings. Also contact support, maybe you will be prompted for a different solution.
@tank666 it resolved it to some extent but didn’t fully resolved. The figma get’s stuck completely very often and starts to work again. I believe we have to wait for the update from either figma or intel hd driver. Let’s see. Thanks anyway.
on a hardware accelerated browser getting this error. Without hardware acceleration, everything is fine (for now).
I just don’t have time to see this error in the application. The application turns into a “gray brick”
I’m confirm this problem. I have an I5-11600 (UHD 750) and also have this problem. Figma works well in Firefox, but in all chromium browsers - crashing browser (or the program does not respond)
Did you tried the latest hd driver from intel on the link below. It worked for me last time when I installed. Because after that I moved to external GPU so not sure if it still works. Give it a try.
