counterAxisSpacing and "auto" value
  • July 23, 2024
  • 43 views
Vincent_Huss
Hi !
in the counterAxisSpacing property, documented here :
figma.com
I see no reference to auto, which is something that can be set in Figma and has an effect similar to justify-content: space-between in css/flex
Am i missing something, or is it not implemented in the API?
Thanks
James_Yang
  • Figmate
  • July 23, 2024
You should look at the counterAxisAlignContent property if you want to understand the spacing between tracks, which should have 'SPACE_BETWEEN' instead of 'AUTO' in this case.
If you’re more interested in the spacing along the primary axis, then you can look at primaryAxisAlignItems.
Check out this page (layoutMode | Plugin API) if you want a list of all the autolayout-related properties.
Vincent_Huss
  • October 3, 2024
Hi ! i’m sorry i forgot to reply to this !
thanks for your insight, it totally clarified the misconception i was having about that.
Cheers
