Hi,
I tried to install Code-connect following code-connect/cli/README.md at main · figma/code-connect · GitHub
I tried installing globally and locally @figma/code-connect but have the same issue.
Here is the issue I get after thefigma connect create "https://..." --token <auth token> command, and can’t solve it even with GPT:
I tried uninstall, cache clean, re-install, and still have the same issue. I’m turning crazy
Do you have any idea?
