Changes to the nested object aren't applied when changing the variant of mother object
Ewa_Bak
Is there a way to keep changes applied to the nested when changing the variant of mother object?
For example I have this component which has nested pill component. If I make changes to child component, like changing the color of this pill this change won’t be applied when I will change variant of this child component.
Dennis_N
  • 191 replies
  • January 18, 2024
This should work out of the box without any special tricks.
All you need to ensure is that namings match across variants.
See:
example.fig (62.8 KB)
Ewa_Bak
  • January 18, 2024
Thanks! I found that what caused the problem was that I changed original color of nested component. Is there a way to have different color than mother component and still be able to change this color and keep it while changing variants?
Dennis_N
  • 191 replies
  • January 18, 2024
Depending on what you are exactly aiming for you could do things like this:
example2.fig (33.0 KB)
(I used the base component method and exposed the nested properties)
Ewa_Bak
  • January 18, 2024
Thanks! I seem to have still problem with it in my original components but its working on another ones.
Dennis_N
  • 191 replies
  • January 18, 2024
Resetting everything often helps.
