Absolute position from Figma plugin
  • February 27, 2023
  • 4 replies
  • 916 views
Dhairya_Shah
Is there any field returned by the figma plugin which will help identify the absolute position CSS property for the frame?
  • 4873 replies
  • February 27, 2023
Dhairya_Shah
In some cases, layoutPositioning is set as AUTO, but the component uses Absolute positioning. Is there any way to handle such cases?
  • 4715 replies
  • February 27, 2023
Do you mean that in UI an object has absolute position, but in the API it doesn’t? Can you share an example?
Stephane_Popout
layoutPositioning property is applicable only for direct children of auto-layout frames.
If there is no autolayout on the parent, then it’s also a position absolute
