OG_Can
Jun 27, 2023 10:27 PM UTC
Use percentage for size variables
Hello. I was wondering if it is possible to have percentage values in variables, like setting percentage value for frame widths or shape sizes (etc.) that have variable modes applied to them? Percentage values could respond better to content that varies within a frame or frames within frames.
Abdulaziz_Lawaj
May 21, 2024 6:43 AM UTC
It will be easy if using manually and so helpful, I hope to apply this feature, its from my biggest needs
Abdulaziz_Lawaj
May 21, 2024 6:47 AM UTC
I applied this way but its so difficult and not helpful
Rodrigo_Fernandez_Suarez
May 23, 2024 8:24 AM UTC
Hi Guys,
@OG_Can I think i have use case also.
Progress bars: From Figma community to personal experiments building responsive progress bars are not great…
What I do is:
Level 1: Get a Main Frame (Main Container) apply autolayout → and fill with no padding so it adapts to the Page
Level 2: Add additional Container (Frame) with autolayout so if needed round corners of progress bar and apply other effects; autolayout → paddding 8px
Level 3: Add 2 Frames: First with the % and the other with fill
So this works fine if I make variants based on predefined frames, but if needed to adapt to all screens I’m toast. So If in Level 3 if the left frame was X% of the Level 2 frame and the other in fill then it would ajust just fine.
Sassy_Ilieva
May 24, 2024 5:10 PM UTC
I believe percentages for variables can be very useful for line heights. Setting only 2 or 3 variables, such as 100%, 120%, and 140%, will prevent the need to adjust the line height to a numerical value. Currently, if you want to cover all screen sizes, the font sizes might range from 12 to 20, requiring you to create at least 8 to 16 different line heights.
Eva_Willebrands
May 30, 2024 10:05 AM UTC
Yes please! and also for Letter spacing! It doesn’t make sense to have fixed numbers for Lineheight and Letter spacing. With that, in our system we would have to add a variable for each textstyle, whereas if you do it in percentages you would only need 2 or 3. For example: 115% lineheight for titles and 150% for body.
Eva_Willebrands
May 30, 2024 10:13 AM UTC
To have percentages in autolayout would also be great. Or maybe you can make this dependent on grid, so that you can specify a number of columns for example in a grid of 12 columns. You would als have to take the gaps between columns into account so that is a little more complex.
S_e_b_a_s_t_i_a_n
Jun 12, 2024 12:34 PM UTC
Kind of weird, because there are some cases where relative values (%) are possible like here (letter spacing):
And when appling a variable it only supports pixels:
That’s bad and should be supported.
Ge0
Jun 30, 2024 12:27 PM UTC
+1 Strongly needed. For instance, during development, I always use the ‘calc’ function for mobile sizing. For example:
@media screen and (max-width: 479px) {
    html {
        font-size: calc(0.75rem + 0.42vw);
This method is efficient and generally ensures that everything fits perfectly with minimal adjustments. The challenge, however, is keeping the mobile designs in Figma synchronized with the actual scaling used in the developed version. Therefore, utilizing relative size units would be optimal, especially when combined with ‘calc’ to mix different size units. Additionally, incorporating the frame width as ‘vw’ should be quite feasible. It should also be possible to set a base font size in Figma for specific frame widths.
Please add 😇
Michael_Staton
Jul 2, 2024 2:23 PM UTC
Please dear God, prioritize this. It would save SO much work.
Michael_Staton
Yeah that’s how it should actually work, but that’s not the way it works in Figma. Causes so much pain and violations of the DRY principle.
