Transfer from Make to Design
  • June 5, 2025
  • 60 replies
  • 41413 views
Show first post
Vasily Kuznetsov
+1, we need to be able to move figma make → figma design. not all of the apps needs to be typescript, we need design file to be able to move it to that engine/language it needs to be run on
Vasily Kuznetsov
So prefer it to be marked as not solved.
Gökbey İnaç
All other AI design tools let users convert their work into Figma designs. This way, you can start iterating with AI and then fine-tune the results yourself. It also means you can hand off the design to a third-party company for development. However, Figma does not allow you to edit Figma Make files as regular design files, and you also can’t hand off designs created in Figma Make. So, what’s the point of using it? Another AI web site builder? We don’t need that, we need an AI assisted design tool that allows us to co-operate with it.
Andrei Katukhin
+1 to the ask! For the immediate use, I just tried to publish a Figma Make prototype and then re-import with html.to.design plugin - got a pretty basic file but it does the job!
Antenor_Aileen
There is no way for Figma Make to be an end all be all solution. There should be a way to customize and refine the design further back to Figma Editor.
This should not be tagged as “Resolved” yet. :)
  • August 28, 2025
Hi ​@Vasily Kuznetsov , ​@Antenor_Aileen , thanks for pointing that out, and I totally hear you!
I marked my response as Best Answer just to make sure the latest update on this feature request is easy to find, especially since there are quite a few replies in the thread. I completely agree that it’s not a “solution” in the sense that the feature is available. It’s more about helping others quickly see the current status (which, unfortunately, is that it's not supported yet)
To avoid any confusion, I’ve updated the message for clarity and switched the topic type to a Conversation, so the reply remains pinned without showing as “Solved.”
The thread will stay open, and I’ll make sure to post any future updates as soon as we have them.
Really appreciate you both for keeping things clear and helping us maintain accurate information here 🙏🏼
Pierrick
  • September 2, 2025
You can do it using the html.to.design Figma plugin
  • Design in Figma Make in the browser
  • Launch html.to.design chrome extension
  • Click on “Capture Figma preview”
  • it will be automatically imported into Figma Design, or it will create an .h2d file that you can drop into Figma design (via the html.to.design Figma plugin)
omeedkashef
  • September 3, 2025
Not true for me
Pierrick
  • September 4, 2025
Not true for me
I’m not sure what could be the issue, here is a step by step guide, with video example 👍
https://html.to.design/blog/from-figma-make-to-figma-design/
Peter_Villevoye
IMHO, the Prototype features of Figma Design are not very rich. Adequate for plain navigation, but not very easy or even capable for more complex interactions or micro-animations. (Smart Animation can get you further, but its features and options are defining the design.)
Did Figma Make solve this ? Partially. In half of the cases it works surprisingly well and creative, in the other half you can spend hours on tweaking what the AI just doesn't seem to understand.
But what's really annoying and making it all quite useless, is that this is just a one-way workflow. Like a stand-alone gimmick, fun to experiment with, but completely unhinged from the Mothership. That's not how users work…
I trust Figma to very rapidly progress in this.
Terry Penman
  • September 9, 2025
Definitely necessary! What is the point of Make if you can’t fully and re-use customize the output?
Monserrat Gutierrez
Adding a like to this,  I was looking for the same question. Once I have a "Make" Design I would like to be able to edit it manually for tweaking and in general apply changes on the fly if managers ask for it
Kristian Hansen
Its an imperfect workaround but its possible to use plugins like html.to.design and pull in the Make content when you are viewing it in a browser…
Lucas Saldanha
Please just make this already, Im tired of using plugins to get the designs from make
Joe Bajin
  • September 17, 2025
It’s been 3+ months of this being requested. I’d love to know where this is on the priority list for the team to allow Make to move everything into Design so that it can then be used there.
That feature alone would solve a lot of issues for people and make this a bit more connected as a tool.
Delany
  • September 21, 2025
I made a quick and dirty vsix extension for VS code/cursor/ws etc. Clone repo, install vsix, command shift P and type figma make add… then select your zip file. It resolves any decompression issues as well as the package.json dependency versioning imports. apologies if anyone has issues, its a hotfix but works fine for me.  Happy coding :) https://github.com/spetro511/figma-make-scaffolder
Can you explain how this can turn Figma Make into Figma Design?
AAL
  • September 23, 2025
Guys, why is there no such conversion??????? It’s the main use case for Figma Make: you vibe-code an initial design and then convert to Figma design to polish.
LeBron James
  • September 24, 2025
This feature would be really useful. Not being able to make edits via a design feels makes Figma Make feel somewhat redundant and not being able to bring it back into Figma Design makes “Figma make” pretty worthless.
DevAurisso
  • September 26, 2025
Commenting to hopefully see an update. I was very excited to see my designs via make only to find out about this limitation right now,,,
Hi everyone, thank you for all your thoughtful feedback!
We’re excited to share an update that could help right now: Teams can now bring their Make previews directly into Figma Design as editable layers 🎉
You can learn more here:
Thanks for helping us make Figma Make even better! Thank you 💜
Eduardo_Moreno
@Celine_ is this available for everyone right now? I don’t see it on my end.
Hey ​@Eduardo_Moreno , not quite, it’s still rolling out and should be fully live by next week (for everyone on paid plans). Thanks for your patience!
SAMER NAJADAUX
@Celine_   i test this feature of copying design into figma file  and its working fine but i want to copy over all app not the same page just
Moses Ochacha
  • September 29, 2025
Hey! Currently You can copy to design and edit is.
John_Hatton_SIL
In Make, you can now choose “Copy Design” and then paste that in.
