Synchronize Figma to FigJam & vice-versa
  • April 22, 2021
  • 114 replies
  • 16834 views
Show first post
Klassapp_Developer
Is it a little disappointing that this feature isn’t core to FigJam.
It’s almost as if “We have this great design tool”, “We now have this great collaboration tool for people to come together on” - and yet ironically the two products aren’t joined at the hip.
Perhaps one day there will be a FigJam plugin or widget to dynamically embed frames from Figma > FigJam. If a quick change to a screen design comes up during a FigJam call, make the edit there & then in FigJam - get everyone’s agreement and it’s reflected in the Figma design file - it seems so obvious to me?
Or on a more basic level if FigJam is used to diagram user-flows with copy & pasted screens from Figma, then the colours or labels or whatever change in the design file, the user flow diagram in FigJam is now out of date with the design file.
Lucy_Tan
  • November 18, 2021
One more vote for this idea. Currently, I’m using Figjam to hand off UI flow to engineers. But every time the mockup changes, I need to copy and paste the frame from Figma to Figjam and link the flow all over again, which is exhausting and bothering me. The sync-up function could be a major standout compared to any other similar tool like Miro.
Kaszonyi_Marjo_H
Need this! So we don’t have to rely on Mural anymore…
Maximilian_Korbel
Is there an update to this feature request? Or its even documented as an feature request on Figma/FigJam’s backlog etc.?
Lindsay_Braun
I think I have read around enough from recent posts that the ability to:
Embed, or input live (always up to date) Figma screens into FigJam is NOT possible.
I want to ideate in FigJam with workflows and ideas, create designs in Figma, and then be able to build robust workflows utilizing the current state of the Figma screen in FigJam. Has anyone seen or tried a good plugin, or does this or COULD THIS exist in the future?
Clara
  • Figmate
  • January 26, 2022
If you embed a Figma frame link inside FigJam (by pasting in the link), it will show the live embed and update with any changes made from the Figma file. I wouldn’t consider this ideal, but hopefully it works in the meantime.
Untitled
Hendrik1
  • January 29, 2022
I think this feature needs to be released ASAP. As designers, we really need it. Combine Figma and Figjam. Two products (Figma and Figjam) cannot be synced. It is very very annoying. We create designs on figma and create design flows on figjam. Every time I update Figma, I need to copy and paste the frame layer to figjam. Make this feature as priority and release it on Feb.
Koen_van_Niekerk
Request would be awesome.
As a temporary solution, having the paste-to-replace work between Figma and Figjam would be great (copy from Figma, paste-to-replace in Figjam to update mocks in a flow)
Alex_Bramwell
White-boarding is an awkward space at the min.
Literally have:
  • Figjam (Thought it would be good to live in Figma’s walled garden).
  • Overflow io (Does what this post is asking).
    -InVision(Becuase FigJam doesn’t have sketch/hand-drawn box capability).
Such a mess 😖
Jackie_Zhang1
+1 To this
This will be really really helpful!
Federico_Polesello
Yeah it is necessary! Any news?
Mikaela
  • March 17, 2022
I think this has to be the number one priority for the product at the moment, or at least, as someone mentioned, having paste to replace so you dont have to fix all the arrows everytime a wireframe changes
Dylan_Jacquay
+1 Please make this a priority!
Linda_Joy
  • March 26, 2022
Yikes - I’m glad I found this thread before I got too deep on FigJam bc I assumed this was possible!
I’m trying to make wireflows that can update as we update our core screens - I figured figjam would be my best bet, but seems like Miro is actually going to work better at this point, since I can push screens there with Figmiro. (Figmiro is a little iffy but at least it kind of works)
Figma, pls tell me you’re going to update this soon so I don’t end up recreating it in FigJam in 3 months
Alex_Martin
This is a really necessary feature!
Dan_Wood
  • April 6, 2022
Yes please!
This is the first thing I’ve felt I’ve needed from Figma/Figjam and I’m glad there’s so many others feel the same. It would make like so much easier!
Mike40
  • April 7, 2022
Push, push. This is the one feature that would make our entire company switch from Miro to FigJam. Outdated designs are a huge problem and FigJam would be a great place to explain flows and let everyone contribute.
Des_Igners
  • April 7, 2022
Boosting this thread!! Without the ability to sync design changes to existing flows, FigJam is pointless. My team will be sticking with Miro.
Davide_Calvo1
Really, this is a no-brainer. I was assuming that it was already possible, otherwise why should anyone put up with FigJam limitations? Please make this feature a high priority, otherwise we will have to go back to Miro, and keep our mock-ups in sync manually! Also, consider that designs pasted into a FigJam file could easily belong to different Figma files.
Julian_Seibert
Without this Feature we our whole company will continue using Miro…
Urgently NEEDED!
zoecheung
  • May 23, 2022
agree, usually use miro instead of FigJam
Pim_Kramer
@Vanessa_Van_Schyndel; we definitely need this feature. It could be an extremely elegant Figma/FigJam workspace feature. And a great way for designers to prepare FigJams, where we can give more context on edge cases / how certain features should work - for handoff’'s to developers & communication and alignment with other stakeholders. Making changes to designs in Figma, will sync perfectly with FigJam (when you say so). Who needs Google Slides or Miro when we could have this?
Curly_Nguy_n
Hmmm, sound like this can be a weekend project for me, this can be done with some workarounds. Basically, the plugins must be both open from the FigJam and Figma files (only one person is enough) to keep the two in sync, without this, the changes will be messed up as Figma doesn’t store object modification time in their API (correct if im wrong)
Geghie
  • June 22, 2022
A million times over, yes! But should be optional.
Jackie_Zhang1
Bumping this again! Really hoping we’ll see this feature soon!
