Suggesting a Command to Add Objects Inside a Frame
  • October 16, 2023
  • 355 views
ChelKroma
Many times, objects are in the right position but are outside the frame. A command to select everything and add them inside the frame would be perfect.
Português:
Tópico: “Sugerindo um Comando para Adicionar Objetos Dentro de um Quadro”
Muitas vezes, os objetos estão na posição correta, mas estão fora do quadro. Um comando para selecionar tudo e adicioná-los dentro do quadro seria perfeito.
  • November 1, 2023
Hey, @ChelKroma, thanks for the feedback!
You can also create a frame around existing objects, whether it’s a single layer or selection of layers. Use the frame selection keyboard shortcut:
  • Mac: ⌥ + ⌘ + G
  • Windows: Ctrl + Alt + G
