Stroke input field bug
  • October 15, 2024
  • 37 views
Julie_B_Fjeldsbo
When clicking in the input field for the stroke-width there is two bugs:
  • the number doesn’t get highlighted. In every other input field, the value gets highlighted and when you write the new value, it overwrites what was there initially. This should be consistent. Right now this stops my workflow a ton of times.
  • When the stroke-with input field is active, there is a very large padding making it impossible to see more than two numbers. So if your number is 10+ or has decimals, you can’t see what the full number is anymore. See screenshot under.
  • October 16, 2024
Hi there,
Thanks for the detailed feedback! I’ve shared this with our internal team. I can’t guarantee it will be fixed soon, but I’ll let you know if there are any updates.
Thanks again,
Toku
Julie_B_Fjeldsbo
Thank you for taking the time to look at this and reply, Toku. 😊
