Sort variants alphabetically (ascending/descending)
  • April 21, 2021
  • 49 replies
  • 16272 views
rzmota
Hi,
Is there any option to automatically sort the items/components in the variants menu? Seems like I can drag them and drop but while having lots of elements it’s quite hard to keep things in the correct order.
I know there are plugins to sort items in the layers menu (like SortIt) but would be great if there is an option to make the same (A->Z, Z->A) for the variants.
It will make life easier.
Kapture 2021-04-21 at 13.42.37
sebastien.giroux
An idea, could you sort the instances (layers) BEFORE merging them as variants?
Jiri_Sindelar
What if you are adding variants as you need them? You can’t break the component and make it again.
Felipe_Moscon
@rzmota
i’m also seriously in need of this feature at the moment. have a ton of variants in several components and would like to keep them organised and listed alphabetically for easier selection when designing the screens. come on, Figma team! you can do it. 😉
Jonathan_Slavuter
I also have a very large list of variants for one of my components and would love it if Figma would auto-sort them in ascending alphabetical order.
micah_david.mn
It seems that Figma does not have any intuitive (and more importantly native) function to sort components by title, ascending or descending. The only option I foresee is ordering the components before they are combined as variants as @sebastien.giroux eluded to.
Oooooh (😲) Figma: we need this feature!
PRO1
  • November 4, 2021
+1
It would be helpfull to sort our variants
Sabrina_Huppertz
I’d also like to have this feature since sorting Icons is very troublesome when having to do it manually.
tank666
  • November 12, 2021
Hey all, I changed the topic category so that you can vote for it.
Ilya_Ivanov
Same case, 2 hundred icons. Sorting before merging won’t work since the component is already a part of the team library and has tons of references across the projects. + The set is not static, people add new items and remove outdated ones.
It would be nice to have a choice of a key property synced with the order of the variant layers. There are plenty of ways to sort layers (manually & via plugins), so it might be rather flexible.
Luca_Vitiello
Same here. A lot of Icons and we add new ones every now and then. It takes ages to find them as they are not sorted alphabetically. When you try to filter them by start typing the name of the variants it stops after entering “_”
Luigi_Rossini
@rzmota am I wrong or you can solve this problem by dragging the variant name tags in the order you want/need?
This will have an effect on the dropdown list as well.
rzmota
  • November 30, 2021
What if you have hundreds or thousands of them? Dragging them around is not the solution.
Ilya_Ivanov
Just to be clear on dragging, here is the real-world usecase:
Please note the scrollbar) I use dragging to keep it sorted, true. However, it takes some time to establish the order in an old lib. And this way is not quite reliable, since every contributor has to put any new icon into its place manually on any update, which is annoying and thus ignored in daily routine practice. Autosorting could solve it for real.
Igor_Stetsenko
@Felipe_Moscon, @micah_david.mn, @Ilya_Ivanov, @Luca_Vitiello: good day to everyone.
It seems that I found a solution to how we can sort Figma variants in 2 steps:
  1. Move all variants out of Variants frame.
  2. Once again combine all selected components as variants.
✅ Done. Sorted alphabetically.
And yes, connections checked, links with these master components was not lost after pushing library updates.
Ilya_Ivanov
Hello, @Igor_Stetsenko
Thanks for sharing your solution!
I can confirm that it works. However, I’d suggest to use it with caution and create reliable backups beforehand, since there might be some unevident pitfalls. Some notes on my personal experience:
  • You have to put the sorting property to the 1st place.
  • Property names are dropped in some cases (not yet ready to figure out the exact reason right now).
  • Not sure if this is totally safe for usage with REST API and plugins, since a new Variant is probably a new instance/node and thus might have it’s own node_id or some other differences in metadata.
Technically, this is a workaround and it doesn’t completely solve a case on teamwork. However, the idea is smart and helpful anyway. Thank you!
Luigi_Rossini
I see your point.
Off topic thought:
about your “real-world” use case, how did you get to such complex set of variants for a component? Do your users understand how to use it?
Just curious 😉
Ilya_Ivanov
@Luigi_Rossini
Let’s say, it’s a matter of a project / library structure. In that particular case the Icon component is a wrapper for the whole library of icons that is shared across a bunch of microservices and is syncronized with React-based component system. The amount of icons involved in a particular interface / bundle build varies, but you have to keep them all together to preserve consistency.
Also, there are plenty of variations of a single icon sometimes. For example, when it displays a state or identifies an entity or status:
Icons are usually used along with captions, colorcodes and a certain area of the layout. The combination is recognizable.
But threre’s even a simplier real-world case. A service supports up to 150+ delivery platforms (YouTube, Spotify, Netfix, Apple Music etc) and uses their logos as icons for report screens, delivery settings and other features. This is a 150+ icon set by default.
Not saying this approach is right or typical, I just state that it exists.
Luigi_Rossini
@Ilya_Ivanov
Thanks for sharing!
It’s always interesting to see how others face the complexity of delivering a design system.
I am convinced there’s no good or bad process. The best is the one that enables designers to unlock business value. At the moment, our design system covers four platforms, two web and two natives. We rolled out the platform across twelve countries. Hence we heavily relied on the variants to cover the different use-cases. Despite that, we preferred to implement an essential structure for the most-used components to avoid too much overhead when it comes to an understanding of when to use what. So far, the design community is happy with the library setup, and we’re satisfied with our KPIs.
All the best for your project!
Felipe_Moscon
you’re a legend. thank you for sharing it @Igor_Stetsenko . 😉
  • January 6, 2022
Wigley_Shashi
I’m creating variants of online merchants logos and need a effective way to organize them alphabetically (not removing them from the variant and adding them back in order - that would be time consuming). These variants are linked to several projects, so the library will constantly need updating. See screenshots
Screen Shot 2022-02-24 at 12.57.03 PM
Does anyone have a solution for this - plugin, figma update etc? Thanks in advance!
Alyssa_Maac
But the issue with this is if the components are already being using on another file then if we do break and combine the components again, we’ll have to replace everything or double-check it all over again.
Rebekka_Karrengarn
We need this feature for organizing a design system!
Sophie_Price
This would be super useful! I’m spending a fair bit of time ordering them manually at the moment, and then as I add new variants I have to go reshuffle it all.
legnaleama
Thank you good sir.
