Hello Figma Team,
First of all, thank you for your continuous efforts in improving Figma.
I would like to provide feedback regarding the slide feature (using frames as slides for presentations or documentation).
Currently, there is no option to set custom aspect ratios (e.g., 16:9) or manually adjust slide frame sizes, which creates limitations when designing and sharing content across different environments.
In particular, as mobile-first content consumption increases, there is growing demand for vertical slide formats (e.g., 9:16).
However, the current slide feature seems to be optimized for horizontal layouts, making it difficult to work with vertical slides without unwanted whitespace or layout distortion.
Additionally:
  • There’s no way to freely set the aspect ratio or size of individual slide frames.
  • The display output for slides is fixed, which often causes layout inconsistencies in real-world presentation or documentation use cases.
If the slide feature allowed custom frame ratios and adjustable presentation display settings, it would enable much more flexible content creation for various devices and contexts.
Thank you for considering this enhancement!
Be the first to reply!
