Quick option to "Detach all variables"
  • October 27, 2023
  • 1163 views
Dustin_Miller1
This is great but there are some cases when a user want’s to bring in a component from another library that has variables attached that you no longer want to use. Say you are building a new library with it’s own variable styles. At the moment there is no way to just detach the current variables when you bring in a component from another library. You have to manually comb through the component and try to find all of the instances where there are variables being referenced from the outside library. Very time consuming!
It would be a life saver to add another option to the quick options panel to “detach all variables”. This way a user could start fresh and add new variables to the component and have no references to the an outside library.
David Natas
  • May 7, 2025
Yes this would be very useful. Also for workflows where you want to use the same designs in a prototype and also in documentation. Where you create documentation and want to make sure the designs don’t change if you toggle variable states, would be great to simply click the frame and say ‘detach all variable bindings’ for all the component instances contained within
