Preventing Resizing to Decimal Pixels
  • September 22, 2021
  • 32 replies
  • 16472 views
Joe_Pendlebury
I love Figma and have enjoyed used it since the very beginning. It has come on leaps and bounds since since its early days.
However, one pain point that continues to frustrate me is the decimal resizing issue, as detailed here almost exactly four years ago - https://spectrum.chat/figma/general/how-to-prevent-decimal-pixels~a6007961-7415-4c1e-9430-7e420491c446
Despite all the other fantastic enhancements in the platform, it is disappointing that this core issue is still present.
Even in the latest Playground file (produced by your own team) outlining the latest ‘Copy & Paste’ advancements, you can see the problem firsthand, as per the screenshot below.
FAO @Figma & @Figma_Support. Please can I ask that you look at this as a matter of priority. I am sure I am not the only one wasting crucial time, painfully and manually, checking and resizing everything back to integer values.
Thank you.
  • October 22, 2021
Kyle_Eberle1
  • March 13, 2022
I re-used the title of an old post and simply changed the 4 to 5 years. No one replied to @Joe_Pendlebury’s question, so I am raising it again. I’m confused as to why Figma still hasn’t addressed this issue.
I laid out my padding on numerous complex screens only to find later that all of the shapes suddenly changed to decimal pixels (I have no idea how or when it happened). Now, I have to painstakingly check each shape all over again - adding hours of extra work and putting an extremely tight deadline in real jeopardy.
Two questions:
  1. @Figma_Support - Will this issue ever be prioritized and addressed? If not, why?
  2. Has anyone found a workaround for this issue? a) My preferences were already set to ‘Snap to Pixel Grid’ so that doesn’t help. b) Selecting ‘Round to Pixel’ only removes fractions from the coordinates, not the shape itself.
Any help here would be most appreciated.
Many Thanks. 🙏
Kyle_Eberle1
  • March 13, 2022
PS - I’m afraid to adjust my padding all over, simply to have them randomly go back to decimal pixels again.
Kleine_Tricia
UH YEA!!! This is really annoying! What is the word from FIGMA on this. Why the radio silence!?
DesignBro
  • July 9, 2022
@Kyle_Eberle1 @Kleine_Tricia
Hey guys. I recently encountered a similar scenario.
How i fixed mine is by looking for any object or element in my design that seems to carry a decimal point in its width and height, delete the decimal points off and the spacing and paddings will appear in whole numbers when i checked it again.
Might wanna try it out. works for me
Kleine_Tricia
Thanks for your response DesignBro. I’m definitely able to go into each element and delete the decimals but when you’ve created hundreds of screens and didn’t realize one element on in those screens somehow ended up with a decimal it’s a huge time suck to go back and edit each screen.
What I’d like is a setting or an ability to lock or snap sizing of elements to whole numbers and not even allow decimals to be created.
Carolyn_Lee
Yes, how can get Figma to respond to this issue. It’s super annoying. If I resize using the scaling of an image it works ok and scales with whole numbers. But as soon as I use the constrain proportions design tools area and type in a specific width or height, it changes the other size to a decimal. Then sometimes when I export that image, it shows up with a thin white line because it’s not rounded to the nearest whole number. So why does the scaling tool work but not the other way if you put a specific height or width in.
My workaround was to uncheck the constrain proportions and resize manually, but that is super slow when you have a lot of images.
Natalia28
  • August 19, 2022
Hey, guys! There’s actually a way. Just go to the Figma Icon, click on “Preferences” and then select “Snap Pixel Grid”. It worked for me 😃
Kyle_Eberle1
  • October 25, 2022
I find that after doing this, it continues to happen. 🤷‍♀️
  • March 23, 2023
Hi, I have this problem as well and went through yesterday and painstakingly removed all the decimals. When I look at the design today, though, there are instances where the space between elements includes decimals AGAIN. Why am I unable to purge my design of the decimal spacing? Thanks!
Benjamin_Berger
Would be great to have an option to round all values in auto-layout. Managing decimals value for layers dimensions and positions is particularly painful to work with both for designers and during development handoff.
Lize_Smith
I have the same issue. I just started a new design and somehow these decimals snuck in. Now I have to go and check each element.
Sketch has a setting that avoids this. Why can’t FIgma?
Select the Object and Click Preferences-> Snap to Pixel grid. It worked for me 🙂
MattBraun
  • May 24, 2023
One of the worst bugs!! I think some people now think that they can actually design in fractional pixels! So sad and annoying!! Even with all that money, they’re doing dumb shit instead of fixing the core issues or buying out some plugins that fix things like this.
so, 2023, new figma user, is there a way to turn off non-integer pixels yet?
  • August 12, 2023
So, if you have checkmark on Snap to pixel Grid ( Ctrl+Shift+´) all elements starts build without decimal pixels.
IraX
  • August 12, 2023
For those referring to “Snap to pixel grid”, that is not the issue, although it is tangentially related. The original post is talking about resizing, which does not yield integers unless you’re resizing to an equal ratio. I also would love a change in that behavior so resizing will automatically round up or down to the whole value (or provide a preference).
Funny enough, auto layout will account for this with its spacing, but the container’s width/height will then be a decimal value, which then affects the x/y position of the next element.
“Snap to pixel grid”, which I always have enabled, lets you place and draw elements on and at whole values.
Fortmindz
  • September 27, 2023
Hey There’s actually a way. Just go to the Figma Icon, click on “Preferences” and then select “Snap Pixel Grid”. It worked for me.
Rick_Carruth
Yes, please! And Snap to Pixel Grid is not the answer. I use this religiously and I still continue to find decimals. It’s super annoying to think everything is fine, notice a decimal, and start investigating to only find more and more. This is my biggest Figma frustration due to it being a regular occurrence. Can we just round up or down if it senses decimals? Something?
Fabiano_Peixinho
Hi guys!
I’ve realized this happen when I use mouse for moving objects. When I use keyboard arrow, not happen.
Andy_Liu
  • November 30, 2023
Hi guys, you can try using the Pixel Cleaner plugin [https://www.figma.com/community/plugin/1126145146212131907/pixel-cleaner](https://Pixel Cleaner)
It works great and removes decimals in components with one click. This creator is a hero in my book. 😀
Thanks a lot! It works for me.
Jack_Reeves
  • April 3, 2024
ANother Figma bug that causes real issues in you core mission yet after 4 years still no one cares to answer? Why even have this forum. Im going back over all my previous tickets and commenting because its the same on all fronts?
Craig5
  • May 16, 2024
Bump. How in the world is this still an issue. It’s without question the most annoying bug in Figma.
Mike43
  • May 23, 2024
I love pretty much everything about Figma, it’s incredibly flexible, satisfying and easy to use. However, one thing that desperately needs changing is the use of decimal points within our workflows.
An option to disable this and instead round shapes to the nearest pixel would be ideal. I shouldn’t have to rely on plugins (Pixel Perfect) to reset the size of objects by 0.25 of a px - overall, it wastes time that many of us rely on to meet tight deadlines.
