Hg_Msnc
Feb 28, 2025 10:54 AM UTC
Mutually Exclusive Boolean Properties — Radio button boolean properties
Hi everyone,
I often run into an issue when creating components: I want certain properties to be mutually exclusive.
For example, inside a component (most of the time it’s a product card), I have Block A, Block B, and Block C, each controlled by a boolean toggle. If I want to switch from A to B, I have to manually turn B on and A off. This quickly becomes tedious, especially with multiple options.
While variants are an alternative, they become impractical when dealing with many of this mutually exclusive choices, and they add too much complexity and file size.
Conditional logic could also work for this but it is such a pain to do for this simple and recurent use case that I consider it as not a viable option for a day-to-day workflow.
Feature Idea:
It would be great to group boolean properties so only one can be active at a time—like a set of radio buttons instead of multiple independent toggles.
Would this help your workflow too? What do you think?
    Daniel Zuba
    Mar 11, 2025 1:19 PM UTC
    Up this feature, it would simplyfie a lot building components, if we would be able to make work boolean similar to dario button behaviour.
    Walker_Amanda
    Nov 4, 2025 3:05 PM UTC
    I still prefer toggles to radio buttons but it would be incredibly beneficial to be able to link boolean toggles together as mutually exclusive - so toggling one on immediately toggles the others off (if they’re linked). The workarounds for this right now are not ideal.
    Pieter_Spoelstra
    Oct 4, 2026 10:11 AM UTC
    Would love this feature. A simple switch that that would contain a group of components for which you can decide if they should become visible or hidden at the flip of the switch. At this moment you have to create complex layer stacking or large grouped variants to get something similar working. Being able to create a group of components of which some turn on and others turn of would be such a time saver and produce way cleaner designs.
    richard78
    Oct 4, 2026 2:34 PM UTC
    I also love this feature.
    Amorzeria
    Nov 9, 2026 6:16 PM UTC
    This would be so useful there is no real work around here I’m finding for a lot of cases. Would make life a lot easier
