More Folder
  • November 21, 2024
  • 270 views
daniil.krylov
Hello! I use Figma for large projects and really, really don’t want folders within folders. Straight to 3-4 levels
Can you add such functionality?
Alok
  • November 21, 2024
Currently, Figma does not support a folder system with more than two levels (teams → projects → files), but here’s what you can do to organize your work and simulate a deeper structure without clutter:
Workarounds for Multi-Level Organization in Figma
1. Use Consistent Naming Conventions
  • Since Figma doesn’t have deeper folder structures, you can create a naming hierarchy within project and file names to act as pseudo-folders.
    • Example:
      • Project Name > Component Library
      • Project Name > Wireframes > Home
      • Project Name > Final Designs > Mobile
  • This helps group files visually when searching or sorting.
2. Create Sub-Projects for Larger Teams
  • If you’re managing a large project, divide your work into sub-projects under a team:
    • Example:
      • Team: “Website Redesign”
      • Sub-projects:
        • “Wireframes”
        • “UI Components”
        • “Prototype Testing”
3. Use Figma’s Tags for Quick Filtering
  • You can tag files using consistent prefixes or keywords in file names.
    • Example: [Mobile], [Desktop], or [v1.2].
  • This allows you to search or sort files efficiently without the need for nested folders.
4. Use Third-Party Tools for File Organization
  • Use external tools like Notion, Google Drive, or Dropbox to organize Figma file links in a multi-level structure.
    • Example: Create a Notion page with nested categories and link directly to your Figma files or prototypes.
5. Request the Feature
  • Submit feedback directly to Figma requesting multi-level folder support. You can do this by:
  • Be specific about your use case and why it’s essential for managing large projects.
Why This Feature Might Be Limited
Figma’s current flat structure is designed to simplify collaboration and reduce complexity for teams. Adding multiple folder levels could make navigation cumbersome for less structured workflows. However, a customizable structure could be helpful for advanced users like you!
Let me know if you’d like help with drafting a feature request or organizing your files more effectively. 😊
