Could you implement a feature that allows the AI chat to memorize the conversation and then archive it to clear all the history messages? It tends to get really laggy at some point when the conversations has been going on for a few days. This is typical in Chat GPT as well. But this needs to be sorted. When I work with figma make at the moment i haev to write all my updated request in a notepad document and then paste into the chat becuase its lagging so much. And if claude sonnet doesnt allow this workflow, come up with something else. Thanks in advance!
Currently having the same problems. I am really confused why Figma decided to load the WHOLE chat in figma make. I am at revision 550, and because of the chat the product gets so laggy. It should at least only show the last 20 messages. The lag really affects my productivity
I'm having the same
Up, same here!
👋🏻 Hey, everyone! Thanks so much for taking the time to share your experiences and suggestions around memory handling — your input is incredibly valuable as we continue to improve.
If you’re open to it, we’d love to take a closer look where you’re running into this behavior. You can share the file URL with our Technical Quality team via this secure form: Submit a request, and please grant edit access to support-share@figma.com. This won’t impact your billing and will help us better reproduce and investigate the issue.
I’ll also make sure this thread and your insights are surfaced to the right team members as we continue iterating based on feedback from designers and developers. Thanks again!
Hello again, everyone — quick update after connecting with the product team.
They're actively working on improvements that should lead to better overall performance. While there's no set timeline that I can share out just yet, I wanted to surface a resource that may help in the meantime: Figma Make Project Migration Guide — a step-by-step walkthrough for spinning up a fresh file with your existing code and structure intact.
Appreciate your patience as things progress — and definitely keep us in the loop on how it's going.
