LAUNCHED: Elements now stick to the top when vertically scrolling in prototyping
  • January 25, 2021
  • 136 replies
  • 101012 views
Show first post
Greg5
  • December 14, 2021
Great trick!!! I´ve been all day trying to accomplish a very close use case. it is not what i needed. (because an element already in the viewport should change to sticky), but I made some changes and it does the trick for explaining the experience for the user. Thank you!!!
JJ1
  • January 24, 2022
Yes and yesterday! I needed this years ago and very much still do today…
Please and thanks.
Tarik
  • January 28, 2022
design tools built on actual web renderer
Do you know any?
mattaningram
  • January 28, 2022
Check out https://www.plasmic.app/ and in the future when it comes out of beta maybe https://www.modulz.app/
I tried Framer and it was way too limited and over-reliant on React to do anything beyond the basics.
Hunter_Wilhelm
I might actually switch from Figma if these other platforms have the sticky feature. Others should too.
Param_Patel
This feature is a must! I hope Figma look to get this feature on there soon. Can’t see why it can’t be done. Most of the sticky aspects are there, it just requires a beginning and end positioning as constraints.
rnwicaksono
Yessss! I know Figma can do it! Go Figma!
Goncalo_Barros
Yes please Figma! I need this feature to do my school work! You can do it Figma! 🙏
Prouvost_Nicolas
That is missing indeed, and would be very useful, please!!!
Thanks in advance
IraX
  • February 14, 2022
We all know that these methods are hacky and ultimately yield decreased usability, which may or may not actually occur by chance if you weren’t driving the prototype yourself (e.g. testing). That being said, there is still a simpler way to produce a fixed-position element at a certain scroll position, and more importantly with a single frame as an overlay that can be reused for any other frame (I say this because I have seen Mouse enter/Mouse leave methods that required a connection to a duplicate frame, and double content to maintain is just… no).
scroll-fixed-prototype
I have one shape in a scrolling frame, positioned where (when) I want the fixed element to display. Unfortunately it is still based on hovering (so mobile testing in the app is out). The “While hovering” interaction gives you two states in one (on and off), so that is set to “Open overlay”. Still not perfect, but easy to do and maintain.
Figma – 20 Feb 22
Jeremy_Dennis
  • February 18, 2022
Thanks for the explanation. The odd bit to this method is that it does not work with frames with transparencies or blurs.
IraX
  • February 18, 2022
I’m not sure what you mean. It’s just a 0% opacity layer that scrolls in and out of view. No sibling or parent frames with transparency or blur affect it.
Ahmed_Khames
WOW! Thank U 🤍
Alexandra_Gruenagel
I’d really love to have a sticky feature. ❤️ 🙏
Automatically stuck to the bottom of the screen would be very cool.
goncalo.fonseca
So are we getting this feature or what? This would be super handy to make the prototype experience more realistic. Also, it will be just a matter of time until the competition offers something like this.
Kelco
  • March 24, 2022
Please, I need this!
Alexey21
  • April 3, 2022
Exactly what I need!
Henrique_Pires
Worked like a charm. Thanks for sharing!
dennsi
  • Active Member
  • April 8, 2022
Oh yes I need this!
Randy_Assell
Please, please, please…. Add “fixed position when scrolling” capability to items that have autolayout. OR, a native workaround to remedy the issue. The case that I run into on nearly every project is I will have a webpage that is set up to auto-expand with the content throughout the page. For example, accordion panel content and expanding sections that will change the overall document height as items are toggled on/open when in the prototype preview. This is great for more accurate client presentations to show the intended usage of the design. The trouble is when a client wants a sticky nav AKA “fixed position when scrolling” within that prototype, we have to do some pretty odd workarounds to make this viewing experience seem natural. Or we have to simply leave it static and reassure the client that the developed page will have the sticky nav fully functioning. Not ideal to ask the client to have a good imagination about how the end result will function.
1640max
  • April 13, 2022
This defenitely should be in Figma. Seems to be easy to implement.
pauline4
  • April 21, 2022
Yes please @figma treat us with some ‘position: sticky; top: 0;’ 🥰
Jessica11
  • April 22, 2022
Yes!! Thank you so much this is a great workaround.
Alex_Boschmans
Ah. So that’s why I can’t seem to find “fixed position when scrolling” no more in the side bar… it’s gone for auto-layout items. Bummer.
Des_Igners
  • April 22, 2022
Boosting this! Same use case as Original Poster but for a mobile app: I have a screen that I want to auto-expand to fit its contents as different accordion menus are expanded/collapsed BUT I still want the header and footer navs to be sticky to the top and bottom of the screen, respectively.
An additional ask would be to set a minimum frame height for the parent frame (screen) because when all of the accordion items are collapsed, the page contents don’t fill the length of a mobile screen.
