Amadeusz_Wasik
Oct 7, 2025 10:31 AM UTC
Improvement/fix - Inherit icon color adjustment on the main component
A few years ago there was a fix - The icon on the instance inherit color override, imposed by main component, when swaping icon or changing variant. Great!
but…
 Problem
If I modify the icon color on the main component - change color style or manually pick new one, doesn’t matter. The instance with swapped icon doesn’t notice the change!
Steps to reproduce:
  1. Place an instance
  2. Swap the icon on instance
  3. Change variant's (main component) icon color
  4. Instance's icon color will remain not updated
Note: Of course, all layers properly named to keep the naming integrity.
The example:
Current, far from being perfect, workaround:
  • If you change an instance to a different variant and change it back, the color will update. Obviously, a lot of effort when you have 15k instances of the modified badge.
  • Use unique variable (semantic). Modify value but don’t touch the name! Sounds nice but be real, semantic naming for each element is an overkill for 80% of the products.
  • Hated but still working - color overlay by union. Old but stable workaround. Unfortunately, force to use bounding boxes for propper sizing and allows a single color only (doesn;t support accents).
 Solution?
The Figma have to improve listener for the color adjustments. It works if the color naming is kept - style or variable with dedicated name. It fails then the color names changes - other style, variable, custom color name.
AlicePackard
Power Member
May 4, 2026 1:34 AM UTC
I didn’t realize this was an issue! Seems like a pretty big flaw. I agree, this should be corrected.
Does this dynamic also exist when that button component is published, and then instances in downstream files must accept those updates?
I write about building excellent Figma components on my blog: https://alicepackarddesign.com/blog
AlicePackard
Power Member
May 4, 2026 1:49 AM UTC
I wanted to tie-in an older thread about the exact same issue:
AlicePackard
Power Member
May 4, 2026 1:52 AM UTC
And another one!
AlicePackard
Power Member
May 4, 2026 2:17 AM UTC
Nik3
Sep 22, 2026 1:55 PM UTC
We have the exact same issue in our library. It has been present for years. Should definitely be fixed
