AndyGandy
April 10, 2021
Fix Position when scrolling for background (or any other layer not on top)
  • April 10, 2021
  • 25 replies
  • 19750 views
Background scrolls with other elements. When I set “Fix position when scrolling” it jump upper and overlap other elements.
  1. Goal
Make background static when other elements can be scrolled on top of it.
  1. Solution
Add 3rd tab of scrolling type in the next order:
FIXED
SCROLLS
BACKGROUND or “BACK ELEMENTS” which is fixed but placed under the "SCROLLS’ layers.
Thanks!
Puristi
Why not just be able to put fixed position elements wherever you want. I don’t understand why they have to always be on top.
Andy5
August 2, 2021
I agree that you should just be able to put fixed elements wherever you want in the layer stack. I’m running into an issue like this in my current project where we have a slight gradient in the background that we want to be fixed on scroll, but we also have a top nav bar that content needs to scroll under. I’m aware of the nested frame solution, but it doesn’t really work for this application because the scrolling frame has to have clip contents on, which then hides all of the content further down on the page.
Kamel_Benslimane
August 3, 2021
Daniel_Duvana1
October 5, 2021
I agree with @Puristi and @Andy5 , I would like to be able to fix objects without having them be on top. I also am trying to fix a background, but this can’t(?) be done without the background covering everything else right now.
EDIT: I found a solution in the thread “Fixed background in prototyping” here on the forum (can’t include link because links are not allowed, search for it to find it)
Power Member
October 5, 2021
Here is the file with examples: https://figma.fun/GfJsF7
Andy5
October 6, 2021
Quick followup to this. We ended up solving this by making the background gradient into a component, then copying that component into the background of our header bar. In this scenario you can have clip contents for the scrolling frame off, and it will go “under” the header bar without being seen.
A little bit of a hacky solution, but it worked out in the end.
Denis_Davydov
December 4, 2021
Figma developers, please remove this fixed/scrolls “feature”, it’s just awful! Why is it that when I mark something as “Fix position when scrolling”, it automatically moves up into a separate category? It makes absolutely no sense and just messes everything up. Why does this feature exist? If I need to move some fixed layer/folders/framer to the top - I can do it myself, thanks, no need to do it automatically! What makes you think that if I have fixed the position of some layers, then I necessarily want to see it on top of other layers?🤷 This is so annoying I just don’t have the words, I haven’t seen anything like this anywhere else. I found some “crutches” on how to get around this “feature”, but I don’t feel like doing such silly things. Please fix this or make it possible to disable this “feature”. Thank you.
Jenny1
January 21, 2022
My use case is a modal that scrolls on top of a static background. Currently, on scroll all the background elements overlap the modal.
Reference/example: In Trello you open a card and can scroll the modal while the background is static.
Adam_King
February 2, 2022
The use case Jenny1 described here is incredibly common. How this is not possible baffles me.
Jeremy_Dennis
There are SO many “hacks” that I have had to do because of little things like this. It’s out of hand, especially when it comes to nested components. There are so many odd things that I have to do, or so many unconventional ways of layering things just to get a prototype to behave how I want it.
Please do not make this a whole year of users begging for this problem to be fixed. If we have to spend a lot of extra time trying to hack our way though a prototype build, I am confident teams will start migrating to a more robust program like Adobe XD.
